20 Most Recent Apple Studio Display 17" LCD Monitor Questions & Answers
Will not power up
You have plugged the display into a wall socket as well as the DVI connector to the MBAir and turned that on right? J
8/31/2017 3:32:17 AM • Apple Studio... • Answered on Aug 31, 2017
0answers
I purchased this monitor and a powermac G4
did you check the input and output voltage it must be the same
3/17/2010 7:21:47 AM • Apple Studio... • Answered on Mar 17, 2010
2answers
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
1/13/2010 1:42:37 AM • Apple Studio... • Answered on Jan 13, 2010
Intermittant power up
the power supply is separate from comp. see if transformer is getting hot. that box with power wire thats between the monitor and outlet if there isn't one that means the transformer is inside the monitor is if faulty you need to change the transformer. hope this helps
11/29/2009 12:10:39 AM • Apple Studio... • Answered on Nov 29, 2009
3answers
I AM TRYING TO CONNECT MY APPLE STUDIO DISPLAY TO
Your Studio Display uses an ADC connector, which is very much like DVI but also supplies power for the monitor and adds USB pins so that you can use the USB on the monitor. In order to use it with something that has DVI instead of ADC, you need this adapter from Apple; there are a couple places that have it $5-10 cheaper, but you may as well get it from the people who made it, Apple probably has a better return policy than anyone else in a situation like this. You hook this adapter into the wall and into your laptop, and hook the monitor into the adapter. Hope this helps!
11/11/2009 11:25:27 PM • Apple Studio... • Answered on Nov 11, 2009
Will new MacBook work with 17 inch Apple Studio Display?
If you own just a Macbook this is what you need http://store.apple.com/us/product/M8661LL/B#overview
If you own a Macbook Pro http://store.apple.com/us/product/MB570Z/A
Make sure you do the full research on these things, so that you don't spend money on the wrong thing, adapter and connectors can be somewhat confusing.
8/17/2009 8:59:27 PM • Apple Studio... • Answered on Aug 17, 2009
The image displayed is in photo negative (what
I found that where the monitor connected to the adapter there had been a cat hair; once the hair was removed the colors were normal.
6/26/2009 3:49:28 PM • Apple Studio... • Answered on Jun 26, 2009
Apple monitor
I THINK YOUR DISPLAY COLOR PROBLEM.
DEGAUSS YOUR DISPLAY, CHANGE YOUR DISPLAY COLOR RESET IT TO DEFAULT SETTINGS.
3/24/2008 6:05:41 PM • Apple Studio... • Answered on Mar 24, 2008
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
11/25/2007 5:10:47 PM • Apple Studio... • Answered on Nov 25, 2007
10answers
Isn't there any manual procedure to migrate apple mail to windows outlook?
Unfortunately, there is no way you can transfer your apple mail email database to windows outlook manually. You will have to take help of the third party tools that you are talking about. Here is one I feel is much superior to others and provides quick and hassle-free migration from apple mail to windows outlook. Apple Mail to PST Converter
4/22/2024 1:35:37 PM • Apple Computers... • Answered 3 days ago
5answers
How do I link Apple Music to echo
Turn Bluetooth on and pair with your echo
3/21/2024 4:31:24 PM • Apple Computers... • Answered on Mar 21, 2024
2answers
I am a new customer t o Netflix. I joined yesterday and got number. I am on the net at home and have Apple TV. How to I start watching Netflix on Apple TV?
Connect the Apple box to the TV with a cable. Using the TV remote select the input port you connected the apple box to. ie HDMI. Click the center button on your apple remote. You should see a Netflix icon. Select it and then log in to your Netflix account
1/18/2024 2:28:12 AM • Apple Computers... • Answered on Jan 18, 2024
3answers
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
12/28/2023 6:55:45 AM • Apple Computers... • Answered on Dec 28, 2023
My I pad is gone. Sister gave me a used apple 1. How do I set up apple I'd and password
if it doesn't have an existing apple id on it can set it up with yours or use iTunes on your computer and restore it to your existing account
4/8/2023 4:09:31 PM • Apple Computers... • Answered on Apr 08, 2023
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video. To preserve the date and time information on your downloaded videos, you can try the following:
  1. Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
  2. Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
  3. Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
3/20/2023 10:55:30 PM • Apple Computers... • Answered on Mar 20, 2023
2answers
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
  1. Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
  2. Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
  3. Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
2/24/2023 7:36:24 PM • Apple Computers... • Answered on Feb 24, 2023
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey). The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system. If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app. Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue. You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue. If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
1/12/2023 12:36:43 PM • Apple Computers... • Answered on Jan 12, 2023
2answers
McGourment App Will not Open ?
The developers do this on purpose. They give you the free version to build up subscribers and improve with updates. Then they bring out the paid version and forget about the free version. https://apps.apple.com/us/app/macgourmet-deluxe-4/id726472926?mt=12 There appears to be an Upgrade Migration Tool. https://marinersoftware.deskpro.com/kb/articles/how-do-i-upgrade-to-macgourmet-deluxe-4-from-my-current-version and you end up with this https://marinersoftware.com/product/macgourmet-deluxe/ ..
1/6/2023 10:21:24 AM • Apple Computers... • Answered on Jan 06, 2023
Apple Studio Display 17" LCD Monitor Logo
21 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
am trying connect apple studio display
  • Computers & Internet
