20 Most Recent Samsung RF266AE (260 cu ft) Refrigerator Questions & Answers
Sumsung rf266 fan noise
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
4/10/2015 7:39:44 AM • Samsung RF266AE... • Answered on Apr 10, 2015
Rf 266 is leaking gas.
Thats a very big leak. open freezer do u smell it? Look mat the lines any of them oily thats a good indication of the leak.Pump down , repair leak , pressure test an vacuum then a charge an your good.
11/11/2014 4:34:50 PM • Samsung RF266AE... • Answered on Nov 11, 2014
2answers
Compressor will not kick on even though lights and
It sound like the fridge is in demo mode. Try holding the top left 2 buttons until it chimes, then see if the compressor comes on. If it seems like your particular model is not the one I described, look in the manual or on the samsung website for a way to put it in and out of demo mode.
7/23/2014 2:40:38 AM • Samsung RF266AE... • Answered on Jul 23, 2014
How to tell if you have a new main control board?
The method off the top of my head, and it may be too late, but, when I am forced into using these nice repair people--I always am there--and when they are done--I always ask to see the old part. Other than taking the appliance apart and visually inspecting the replacement part--I do n=know of any other way. Then, we're left with "trust". Sorry, but that is all I can think of. Good luck!
5/14/2014 6:15:32 PM • Samsung RF266AE... • Answered on May 14, 2014
Rf266aewp
If you have a Lowes nearby, they sell the replacement water filter purifier. I had to replace mine a few months back, and was able to get it at my local Lowes.
2/15/2014 6:56:22 PM • Samsung RF266AE... • Answered on Feb 15, 2014
0answers
Samsung rf26 leaking water inside fridge
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
10/4/2011 9:31:36 PM • Samsung RF266AE... • Answered on Oct 04, 2011
Evap fan noiisy and compressor runs constantly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
9/9/2011 2:40:43 AM • Samsung RF266AE... • Answered on Sep 09, 2011
My refrigerator is leaking water inside fridge and
Leo Ponder
imufo2
8/11/2011 2:52:44 AM • Samsung RF266AE... • Answered on Aug 11, 2011
Refrigerator is not keeping food cold. Temp is set
Most refrigerators have the evaporator in the freezer and use air flow to cool down the refrigerator compartment. Can you tell if the defrost cycle is working, IS there ice on the evaporator. Can you defrost it. Try taking it off the power freeze cycle and also power cool cycle. When you cleaned underneath did you find a pan that had water in it. sometimes the drain clogs up and the condensate just sits in the freezer and refreezes the water, this acts like a blanket and slows down the cooling in the refrigerator. see if you can look at see if the drain is clogged, this may be your problem. You can get back to me and i will see if i can help you. thank you. and a rating would be helpful. thank you. wally
3/15/2011 3:22:50 PM • Samsung RF266AE... • Answered on Mar 15, 2011
The water line is leaking so I am forced to turn
LOOK FOR SMALL DIAMITER WHITISCH PIPES AND WATER CONTAINER. MOST PROBABLY ONE OF THE CONNECTIONS IS LOOSE. CUT OF THE END AND REFIT THE PIPE IN ITS PLACE
3/2/2011 7:57:33 PM • Samsung RF266AE... • Answered on Mar 02, 2011
Samsung RF266AE (260 cu ft) Refrigerator Logo
48 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung rf26 leaking water inside
  • Refrigerators
