20 Most Recent
KitchenAid KPCG100PM Electric Burr Grinder Questions & Answers
Kitchen aid burr grinder adjustments
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
The blue power on light does not light up when pressed on my Kitchenaid KES100 espresso machine although the high pressure pump runs when the button is pressed. Neither boiler heats up.
You will need to test for where the power stops & check the fuses on each boiler for continuity. If you find any blown then replace the thermostat on that boiler along with the fuses. The thermostats are different rating for each boiler, don't mix them up. It's highly unusual for both boilers to fail at the same time. Occasionally one of the boiler elements can fail, there are 2 elements on each boiler, check them for continuity. If you have any boiler leaks then replace all the seals on that boiler, the steam one is the one most likely to leak. Buy your own seals using the old ones as samples from someone specialising in O ring supply. There are 5 seals on each boiler. Do not purchase rubber or silicone seals, only use Viton seals, they are high temperature.
