Question about KitchenAid KPCG100PM Electric Burr Grinder
Kitchen aid burr grinder adjustments
I just purchased the 4KPCG100PM1 kitchen aid burr grinder.Looks like a nice unit but on the finest setting it is far to course for espresso. Can it be adjusted to a finer set of 15 positions by repositioning the adjuster within the unit.
Posted by hertiger on
espressonist
  • KitchenAid Master
  • 1,711 Answers
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
Posted on Mar 02, 2010
Kitchen Aid Burr Grinder
If the parts are not listed separately, the motor and gears are a completely separate assembly. A replacement motor (assembly) would include the gears
May 06, 2013 | Kitchen Appliances - Others
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Grind size too big even when it is set to finest
Have you used it for awhile already? You might want to try replacing the burrs ($20) if they've been used for a few years.
Feb 28, 2009 | Solis Maestro Electric Burr Grinder
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Dec 09, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Grind
Love your 'handle'!
I'm thinking that there is something in the burr in the unit. Empty the unit and remove the burr. Usually, this is done with a counterclockwise turn. Note how hard it may be to turn...you'll have to reverse this when you put it together. Now, clean out any coffee debris you find. Then, turn the unit over and tap it on a firm surface covered with newspaper. Reassemble and return to service.
Nov 03, 2007 | Grindmaster 810 Electric Burr Grinder
KitchenAid KPCG100PM Electric Burr Grinder Logo
325 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Marvin
Marvin
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
