20 Most Recent
KitchenAid Pro Line Coffeemaker Coffee Maker Questions & Answers
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
The on/off switch is broken.
Hi, the only distributor for Kitchenaid Pro Line parts is Kitchenaid directly. I would recommend calling their customer service. They have a specific parts department. Their toll-free telephone number is 1-800-541-6390 and they will also help you on how to replace it yourself..
Kitchenaid 14 cup programable kcm534er
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in
place. Please be sure to check all of your buttons and see if any are
stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Coffee very weak, some grounds are still dry after coffee is made
I2 have same. Problem = not a nozzle missing, but a black plastic diffuser mounted below the orifice. Plastic becomes brittle and disintegrates within weeks. Pieces fall into grounds so you may never notice. Photo is of pieces I recovered from the grounds. Horribly bad bit of engineering on an otherwise great product. (Saved how much over cost of stamped stainless?) I have not been able to find replacement part, although OEM piece would fail again within weeks. ALL ProLine makers MUST fail in the same way - the plastic part CANNOT survive actual use. KitchenAid should offer steel replacement!
Too much water going into
making coffee very wet? sorry have no idea what u mean by this statement, please clarify this statement, coffee is a liquid composed of water.
