SOURCE: I am using samsung gt-S5350
go to control panel then go to phone and modem click on modems select your phones properties click on advance tab and write this line ' cgdcon=1,''ip'',''TATA.DOCOMO.INTERNET'' hit on OK.go to all program go to accessories communications new connection,conect throw modem acces name TATA.DOCOMO.INTERNET and dial numb.*99***1#. make sure that your pc suite is uninstalled
SOURCE: I am using samsung 3g
you need to know service that your provider for sim service. sometimes, you need to change your sim card type to broadband and get the credit or top up for that broadband. In other case, sometimes they provide us with mobile internet. For this, you can browse internet using mobile only, but can browse using pc.
if you came from malaysia then i can help you because im from malaysia and know how to connect using mobile as modem for pc/laptop. Is easy and cheap. No need to buy broadband. As long your mobile phone have 3G.
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
