Which one did you do first: Did you install ActiveSync 4.5 first, or did you try installing the driver first?
The best way to do this is as follows:
- Download and install ActiveSync (4.5 is what i use both at home and work and it works great with the NEC 900 and 900C's.
- Restart your Windows XP Machine (I assume you don't have Vista)
- Next, follow the instructions for the installing the NEC 900 usb drivers (these drivers should be installed AFTER installing ActiveSync... (it seems to work that way without problems for me).
- Next, restart your xp machine again.
- Now, connect your NEC MobilePro 900 to your Windows XP machine, and it should perform smoothly.
If this does not work for you, you can contact the folks at usedhandhelds.com, they sell and repair, as well as provide support for these machines.
Hope this helps
