Doesn't have a fuse for power seats . Use's a circuit breaker , 25 amp circuit breaker PWR SEAT located in rear fuse box . This rear fuse box is under the back seat . Did you look under the seat to see if something is blocking the seat tracks ? Does the vehicle have memory seats ?
fuse for seat heater
Connie, Check attached links, 2nd. link tells what fuse/relay and location.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to fix heated seats in Ford f350 2003
The following checks and repairs can help you:
1. In the fuse box within the bonnet - check fuse number 22, if burnt, replace it
2. Check fuse 19 in the fuse box inside the car located under the dashboard on the driverside
3. If these steps don't help, the problem may be with the wiring and connection between the module and the seat cushion - inspect it
4. Check if the signal return on the circuit is adequately functioning - if the module is being informed of an active seat
5. If there is a problem - repair or replace the circuit and/or wiring.
CHECK POWER SEAT FUSE.IF FUSE OKAY.CHECK FOR POWER AT SEAT SWITCH IF YES.HOT WIRE POWER SEAT MOTOR STILL DONT WORK. POWER SEAT MOTOR FAULTY.NO POWER TO SWITCH AND FUSE GOOD CHECK FOR A OPEN OR BROKE WIRE FROM THE FUSE BOX TO THE POWER SEAT SWITCH.
There Is NOT a FUSE for the Seat Motor I Have Checked The Manual EXTENSIVELY and for seat Fuse AND "RELAY" the Only fuse is for Auto Seat-belt & Warning Light. I Do Believe there Should be A Relay Under the seat This is Where Most Forgen Vehicle Seat Relays are. AlData Shows NO Power Seat FUSE Or Relay though. Seat "BELT" Motor Module is Under Consel At Park Brake Lever Area----------Hope this Helps
seats use heavy corrent & use relays instead of fuses. check relays in fuse panel. see chart on cover or owner manual for location.
Also, this is for 96 villager seats.
Circuit Protection
Power is supplied to the seat motors through the 30A POWER WINDOW fuse. The fuse is located in the LH engine compartment fuse junction panel and is hot at all times.
The circuit breaker is behind the interior fuse junction panel and prevents current overload and component damage.
