Try it... should work
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
However minimum load for ML121 is 80% load rating.. so 80 watts is ok for 100 watt transformer... 60 watts is low and can cause early failure of transformer.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I currently have a 600 watt power pack w/timer on
20A circuit x 80% service factor =16amps continuous. 16amps x 120V = 1920 wats. Your total would be only 900 watts. I have assumed that since you have a 20A ground fault breaker that you have #12 ga copper conductors. If you had a considerable distance the 16 amps continuous would drop due to voltage drop and so the total wattage would also, but you're way below these levels.
