20 Most Recent Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S Questions & Answers
Whats included in my amazon prime subsription?
You get free shipping on prime products. Free prime movies, prime music, prime games and much more. Check out your amazon account at amazon.com for more information.
4/30/2020 6:11:14 AM • Malibu... • Answered on Apr 30, 2020
3answers
Timer model PB912M10 does not
I answer questions for free.
I specialize in timers and electrical devices.
I hesitate to answer about Malibu power packs because there are no parts or repairs for a power pack, and the owners of this product are angry that such an expensive item is unrepairable and then they downvote a truthful answer that is provided for free.
Here's what I've done for fixya customers.
For hours, I searched Intermatic Timers, Malibulights.com, and the web looking for parts and solutions for the Malibu power pack. There are no parts or solutions.
I purchased a power pack from Home Depot and examined it and then read the manual from head to toe.
The answer is this: if the power pack is not working for any reason and the receptacle has power, then the power pack is busted and you need another one.
However I can save you money on your next power pack, and that may be worth your trouble coming to fixya:
Your next power pack:
1) Match up wattage of bulbs with wattage of power pack.
15 each - 20 watt bulbs = 300 watts = 300 watt power pack ... if you buy the 500 watt power pack for 300Watts of bulbs, then it will burn up the bulbs and the power pack.
2) Replace bulbs as soon as they burn out or other bulbs will burn out and the power pack will burn out
3) When working on bulbs, unplug power pack or the power pack may burn out
4) Use the link below to help plan your low-voltage lighting
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Purchase a power pack:
Home depot sells Malibu power packs.
Lowes sells a Low-voltage power pack similar to Malibu
2/24/2017 4:37:04 PM • Malibu... • Answered on Feb 24, 2017
Timer does not turn on its own turn it manually is fine can l change the timer
There is no replacement timer module sold for the power pack. Plug power pack into cheap wall timer. Link below has troubleshoot steps and warranty information http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/19/2015 8:22:55 AM • Malibu... • Answered on Feb 19, 2015
Timer pegs
10/17/2014 3:33:23 AM • Malibu... • Answered on Oct 17, 2014
Malibu intermatic M L 300 TW
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#manual RTW has ground shield Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:27:20 AM • Malibu... • Answered on Oct 17, 2014
Instruction manual
10/17/2014 3:26:43 AM • Malibu... • Answered on Oct 17, 2014
HOW TO CLEAR TIME on Malibu 8100-0300
Unplug power pack? http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:19:04 AM • Malibu... • Answered on Oct 17, 2014
What is the minimum load on ml300rtw
85% x 300 watt = 240 watt http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:16:40 AM • Malibu... • Answered on Oct 17, 2014
NEED MANUAL FOR ML500TW
10/17/2014 3:09:03 AM • Malibu... • Answered on Oct 17, 2014
Malibu ML300 power pack CAUSES MY WIRES TO MELT
Repalce power pack http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#manual Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:08:33 AM • Malibu... • Answered on Oct 17, 2014
Reset ml300rtw
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot There is no reset button Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:06:08 AM • Malibu... • Answered on Oct 17, 2014
How to set outdoor light timer
Copy following link for instructions and tips:http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/10/2013 2:59:03 AM • Malibu... • Answered on Oct 10, 2013
I had a Malibu ML150 power pack that quit, I need
Cut em off. Attach wires to A and B terminals on ML300.Do not plug in power pack until all lights are wired.Read the product manual.Copy following link for tips to get new power pack to last longer, including 5-year warranty information, replacement trippers, wiring etc:http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/2/2013 1:35:40 AM • Malibu... • Answered on Oct 02, 2013
My Malibu ML300RTW worked for a month or so now
That model has 5-year warranty through INtermatic.But did you install correctly, or troubleshoot correctly:Copy following link and read 'Advisories and tips so power pack lasts longer' and then read 'troubleshoot section' and open links for warranty coverage if needed.http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlKeep in mind that transformers are susceptible to surge event like nearby lightning strike, power resumption after outage.Bring around extension cord from working outlet and listen if power pack is humming.Geneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
9/8/2013 4:24:51 AM • Malibu... • Answered on Sep 08, 2013
Malibu 300 watt Power Pack Timer Directions
Copy following link for step-by-step instructions in form of troubleshoot, plus tips for protecting your product rights, protecting power pack from early failure, replacement trippers, product manual, and 5-year warranty claim requires receipt.http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/12/2012 8:55:13 PM • Malibu... • Answered on Oct 12, 2012
Lights not working
Check if power pack is humming.Copy following link for full Malibu troubleshooting resources.http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/20/2012 3:19:49 AM • Malibu... • Answered on Jul 20, 2012
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
66 questions posted
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
timer not turn its own turn manually
  • Hardware & Accessories
