Most dehumidifiers have an optional port to attach a drain hose to for use such as
in a basement where you can drain into a floor drain. I would shut this during use
and the unit should shut off with a light that says "pan full" or "empty pan".
The pans are located in the bottom of the unit and are made of plastic, usually
holding up to a gallon of water. I would suggest removing the pan prior to using the unit
to learn how it comes out. Hope this helps
Testimonial: "Awesome, thanks "
