Hi arbazfar,
First off, you will need a Wi-Fi connection to hook-up your consoles.
- Select the Wii logo (lower-left corner of the main menu)
- Select "WII SETTINGS" , then "INTERNET OPTIONS" option , then "CONNECTION SETTINGS".
- Select one of the available selections and confirm the "WIRELESS CONNECTION" option.
- Select the "SEARCH FOR ACCESS POINT" ( the Wii console will now look for the best local Wi-Fi connections available).
- Pick your preferred access point and then save your settings (Wii will then test the connection and may ask you to perform an update - just press "YES")
-Go to the "ADDRESS BOOK" (from the Wii main menu under the Wii Message Board).
You should see a Friend Code on Page 1. Share your code with a friend you wish to connect to.
-Once you already have the code, press "REGISTER" in the Address Book, select the WII OPTION and enter the Friend code.
For more readings regaring this matter, you may go to the attached link: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
All the best to you. Hope to hear positive results.
How to
connect your Wii to the Internet
Power on
your Wii console and press the A Button on the Wii Remote to reach the Wii main
menu. Use the Wii Remote to select the "Wii" button. Now,
select "Wii Settings" to access the "Wii System Settings"
menu. Using the arrow on the right side of the screen, scroll to page
two and select "Internet." Select
"Connection 1: None"(Don't see "None" in Connection 1?
Click the Connection 1 button, then chooses "Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access Point Select
"OK" and the Wii will display all the wireless networks it finds. Select
the wireless network that is yours Select
"OK," "Save Settings," and then "Yes."The Wii
console will run a connection test with your wireless network when the test is
completed. You should see the following screen.Then you're almost done! After
your connection test, the Wii console will check if there is a new Wii System
Update available. Once you select "Yes" and "I Accept," the
Wii will begin to download any available updates...
Click here to download repair guide
Power on
Click the Connection 1 button, then choose "Clear Settings.") Click on
Point."
Select
"OK," "Save Settings," and then "yes".
The Wii console will run a connection test with your wireless
network when the test is completed. You should see the following screen.Then
you're almost done! After your connection test, the Wii console will check if
there is a new Wii System Update available. Once you select "Yes" and
"I Accept," the Wii will begin to download any available updates.
