Question about Nintendo Wii Console
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet settings and I keep getting error 52020. Is there another step I keep missing?
Posted by sunnymari08 on
sherwin alvarez
    Scholar:
  • 55 Answers
You can try this step on how to connect your wii console on internet...
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
if this help you please rate me thank you sir.....
Posted on Jul 05, 2011
How to connect to this internet
You go under settings then network then wifi...and you look for your homes wifi address and connect to that type your wifi password if you have...one also you can connect with the Internet wire with an adapter go to this link to get one from ebay
http://m.ebay.com/itm/221711839833?_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20150313114020&meid=0e9e092b8942426dafbb551f5334f328&pid=100338&rk=1&rkt=20&mehot=pp&sd=281773241431&_trksid=p2141725.c100338.m3726&_mwBanner=1
Sep 07, 2015 | Ubisoft Wii U Assassins Creed III -...
How do i get the internet connection on the wii to get netflix
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
Once you have set up your wifi connection you can download the netflix channel from the wii shop channel for free. Then you can follow the on screen instruction when you launch the netflix channel to watch netflix on your wii.
Apr 30, 2011 | Nintendo Wii Console
How to get internet
You basically goto:
Once you have set up your wifi connection you can download the web browser channel from the wii shop channel for free. Then you can use the web browser channel to browse the web with the wii.
Apr 29, 2011 | Nintendo Wii Console
Everytime I try to connect to the internet it wont let me I wanna watch net flix
You basically goto:
If you have done all these setups make sure your selected network and encryption key are correct. If you have an error code search on that error code online.
Internet connection says not connected
You basically goto:
We are trying to connect o wifi and dont know how
You basically goto:
Apr 28, 2011 | Nintendo Wii Console
How to connect the wii to the internet
Apr 25, 2011 | Nintendo Wii Console
I have a usb wireless adaptor why cannot connect to the internet
look its an ADAPTER an adapter ADAPTS to the internet BUT for the internet you neeed WIFI.. BY a ROUTER Or by your DSL set up the wifi and your ADAPTER WILL pick up your WIFI once they ADAPT you can connect to the internet.. RATTTE
Jul 22, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
244 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
