Washing Machines Logo
Anonymous Posted on Jul 07, 2011
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer have afuse? Any other possibility?
  • 1 more comment
  • Anonymous Jul 07, 2011
    as the power indicator does not illuminate, this doesn't appear to be a timer issue or water source issue. Its more main power related. Is there an internal fuse in this washer?
    drain is not blocked. as cycle stopped in mid-cycle with water in the drum, I opened drain and ltsa water flowed out. there's no internal fuse? how difficult is it to replace the control board? Where do I get a new control board?
    and are you saying that a blocked drain would stop the power light from even coming on?
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Jul 07, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232959
Points
12714
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the washer. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
    You are right a blocked drain might stop it from coming on, if that is fine then it is the control board that should be replaced. You can buy the board from any local repair shop and to replace it you have to take it apart completely.
Anonymous
Level 3:
Brigadier General:
  • Master 3,513 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
3513
Questions
0
Helped
868492
Points
10095
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Whirlpool washer Wtw4816w2 will not reset. Tried numerous times as explained in add details.
If you haven't power reset then;
Disconnect the Cabrio from power, unplug or flip breaker off.
Wait 5 minutes before restoring power.
If it still won't respond, then likely a control board/power and/or interconnect issue.
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
The washing machine works fine the only thing is that the spin doesn't work, it starts but never gets to it's optimal speed. Clothes are soaking wet when the cycle ends. Our washing machine is a...
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
1helpful
My eurotech washer is making a horrible noise during the spin cycle...it wont drain or spin what do i do
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
6helpful
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Water does not drain from the machine
The only way for water to be exhausted from the Eurotech washer unit is for the water pump to function correctly. Check for operation of the water pump which can be heard with a faint hum during the water exhaust cycle. Also check to see if the drain port is blocked etc eg with a childs sock. To check for this open the lint filterdoor,remove the lint filter and using an inspection mirror look around paying attention to the 2 ports inside the filter cavity. If filter ports are clear then suspect the water pump. If you can hear the water pump working but the water is not exiting your washer then it is likely the 4 prong impeller inside the water pump has sheered off its shaft within the pump. Change pump and this should solve your problem.
Does not agitate
Motor coupler could be bad.
Top Washing Machines Experts
john h
