I recently bought a new filter and put it in. Water started leaking. I took it out and put the by-pass plug in. Water leaks from under the fridge periodically. Apparently the filters have changed from my last one. I have a Maytag model # 12568AES and I was give the UKF8001
The Dispenser supply usually flows through the bottom, inside toward the back to cool the water. If the puddle is near the back. refrigerator section it's probably this water cooling arrangement. Usually. a number of the tubing loops near the back bottom edge. Connections here or tubing itself may leak. It may also be an undetected leak from the Filter housing or the filter is not properly seated or possible filter housing connections. I have had good success with paper towel detection method. Wrap
or paste, tape towel to suspect leak locations. They will soon appear and point to the apparent leak.
Should still be under warranty? Pursue that route
It/s possible put a paper towel on back side of filter see if you can isolate where the leak is coming from. My guess is the filter isn't installed correctly.
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
That connector is known as a John Guest fitting, and they will sometimes leak. Make sure the tubing is firmly pushed into the fitting on both ends. If it still leaks, you will need to get a new John Guest fitting. Your local appliance parts supplier should have them, or they are readily available online. You are looking for a fitting that is 5/16 of an inch on both sides. If a new fitting dosen't solve the problem, your tubing may have a pinhole leak in it, and would need to be replaced.
If it sat a year in the garage are you in a climate that freezes in the winter time? There is water left in the lines and the filter after you disconnect the fridge unless you blow it all out, so it could have freezed and expanded and cracked a piece. If freezing is not a possibility then i would get a new filter if you havent already, the o-rings on the filter could have dried out from being in a hot garage in the summer and caused a leak. Its a pretty simple system though, the water line comes in from the back to the filter housing and then from there it goes to the water in the door and the ice maker. Another possibility is a line could have got snagged and pulled on when moving it, so check all the connections under the fridge for the water lines. Put some paper towels down under the fridge and have someone dispense water from the door and watch it with a flashlight and see if you can find the water leak, the paper towels will help by showing where they get wet and give you an area to investigate further.
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
very odd that there would be an influx of water to that pan, especcially enough to overflow it. a bit of a pain in the butt to remove that pan, try soaking some water out if it. and see if you can see where water coming from, id be willing to bet that the water filter housing right next to it is leaking and happens to be filling your drip pan, did you replace water filter recently?? perhaps its not seated properly.(regardless removing the water filter should stop the leak)
