The Learning Company Arthur's Thinking Games Full Version for PC Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Anonymous
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Jun 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
104
Questions
Helped
15409
Points
288
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
I cannot install School house rock 3rd and 4th grade
There are workarounds besides using an older version of Windows (dual boot or a separate machine). This requires a licensed version of the older Windows OS. However, if you have the most common version of Windows 7 - Home Premium x64, you'll have to spend some money.
School House Rock - 3rd and 4th Grade works with Win98-XP. So, you can run a virtual computer with the older version of the Windows OS. Then install the School House Rock program into the virtual version of Windows as if it were the only copy of Windows. If you have Windows 7 Pro or Ultimate, or upgrade to one of these versions, you can do this for free. Download and install Virtual PC and XP mode from Microsoft (in order). Other virtual computer programs are VMWare and Parallels. However, with those, you need to buy the program and have a licensed version of the Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. (To check your version, click Start > Control Panel > System and Security > System. If the title of the OS ends with x64, you have the 64-bit version. Otherwise, you have the 32-bit version.) If you have the 32-bit, right click on the installer for the School House Rock software. Select Properties and then the Compatibility Tab. Check the Run this program in the compatibility mode and an older version of Windows. Then click Apply and then OK. Right click on the installer again and select Run As Administrator. You may need to repeat this for the program itself.
I hope this helps.
I installed Windows 7 and now I have no connection to the computer. The printer is connected to the router but won't communicate with the HP G60t-200.
Try to remove the existing printer driver from your computer. Go to Start > Programs > Lexmark Z2400 Series > Tools > Uninstall. Your computer will then uninstall the Lexmark program. After the uninstall process, reboot pc when prompted.
When your pc turns on, check if your operating system is running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to re-install the Lexmark Z2400 Series printer driver: - Lexmark Z2400 Series driver for Windows 7 32-bit - Lexmark Z2400 Series driver for Windows 7 64-bit
Download and execute the file. Simply follow the instructions on your computer screen.
I hope this helps.
System won't recognize downloaded driver, I have installed an update provided on HP's site, but it still won't work. trying to install on a windows 7 computer. had installed it earlier on a...
When downloading a printer driver from HP you will need to ensure that you are selecting the correct OS (eg. Windows 7) and the appropriate version (eg. 64 or 32 bit operating system). These drivers are different and using one on the other will not work.
Windows XP drivers also will not work properly in a Windows 7 environment and the majority of Windows XP drivers are 32-Bit.
1helpful
2answers
My computer is telling me I can not run an x86 build of this utility on a x64 platform. I am running windows 7. What do I have to do to be able to run this program for the new Futura CE-150
x86 means 32bit operating system , x64 means 64bit operating system.Windows is divided into to categories 32 and 64 bit. In your case you might be trying to install 32bit operating system's software or a application in an 64bit operating system running machine. If you are getting the above mention error message than it is clear that your window 7 is 64bit operating system and a 64bit operating system doesn't support 32 bit's software. You only can install software or application you are meant for 64bit supporting.
If you want to know more about 64 and 32 bit CLICK HERE
GOOD LUCK.
2helpful
I am running windows 7 64 bit and am trying to play an old game on it. I would like to play Dark Colony. It will not let me do this probably because the game is so old, but i can't seem to find a way...
well, i have a problem with a game and it came out like 3 months before 7 and it won't play simply because some games have a max versions that it can run on. because the new systems are to complex for a 1997 game, i can help. First of all it is possible to install and use 32-bit software on a 64-bit computer in different ways:
  • Installation of 32-bit compatibility libraries (ia32-libs)
  • A 32-bit chroot
  • Full virtualization through KVM or VirtualBox
  • Another option in a pinch is getlibs. getlibs
A use case for getlibs was installing the Amazon MP3 Downloader software, it is written for 32 bit only and without their software downloading mp3s would otherwise be incredibly time consuming. hope it helps!!!!!!!!
1helpful
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
4answers
Backyard soccer won't work on my 64 bit windows laptop.
Are you using Vista or Windows 7?
As far as i remember Backyard soccer is kind of an old game. It likely only works on Windows XP
I have windows 7 and I have been trying to install hasbro sorry game cd rom but it wont install
You need to read the case that the CD came in. It will list 'system requirements". I bet that the game is written in 32 or 16 bit language and windows 7 is 64 bit and it is not "backwards" compatible, meaning that it won't run a 16 or 32 bit program.
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Top The Learning Company Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
