When I put GOW in my PS3 the game credits come up, then a screen that says I have to adjust the brightness settings by selecting display from the options menu but it won't let me get to the options menu or any where else from that screen. Has anyone else had this problem? How do a fix it?
Say, "Go to settings," or swipe down from the top of the screen and select Settings. Select Display. Adjust brightness using the slider. You can also toggle Adaptive Brightness on or off.
Yes, it is possible to adjust the brightness of the display screen on your Technics SH-EH790 stereo system.
Here are the steps to adjust the brightness on your device:
Press the "Display" button on your remote control or on the front panel of the stereo system. This will bring up the menu for adjusting the display settings.
Use the arrow buttons to select "Dimmer" and then press the "Enter" button.
Use the arrow buttons again to select the desired brightness level for the display. You can choose from "Bright," "Mid," or "Dark" options.
Once you have made your selection, press the "Enter" button to save the new settings.
If you find that the display is still too dim after adjusting the brightness level, it is possible that the backlight or other components of the display are failing and may need to be repaired or replaced. In that case, you may need to contact a professional technician for assistance.
You wont have to delete the save game so you wont loose single player progress, Only the GTA content in the Game Data Utility needs to be deleted which will re-install the game and it's updates.
Before you do that you can try these other things first:
Start GTA up and as soon as you do hold down L1 + R1 continue to hold it as it's loading until you see the adjust brightness screen then release them. Once you see the adjust brightness you can set that backup and continue on as normal. This resets a few things and un-links your social club ID from the game which has helped people with problems starting up.
If that does not help then the next thing you can try is to access PS3 Safemode and use the options RESTORE FILE SYSTEM and REBUILD DATABASE both of these are recommended on Rockstar's Support site to try to help resolve problems. Don't worry you wont loose anything critical by doing these options, Here is the official sony article on safe mode if you want to look into that: support.us.playstation.com/app/answers/detail/a_id/1488/~/safe-mode-on-ps3
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks,
Anand
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
When making a wired connection to the Internet, you do not need to
adjust any of the default settings. If you cannot use the default
settings to connect, follow the instructions below to adjust the
settings.
Select "Network Settings" under "Settings" in the home menu, and then press the X button.
Select "Internet Connection Settings", and then press the X button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the X button.
Select "Wired Connection", and then press the X button.
Select "Easy" or "Custom" and adjust settings as necessary. (Easy is recommended)
Follow the on-screen instructions to adjust the required setting.
Easy: Basic settings are set automatically.
Custom: You can manually enter detailed settings information.
Here's a diagram set up to PS3 wired internet connection
You can take a look at the connection diagram here
