Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
Posted on Jun 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In windows 7, I can't figure out how to turn "tap to click" off. There is no tapping tab. Can you tell me how to perform this task?
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on Jun 22, 2011
Anonymous
Expert
Level 2:
Answers
111
Questions
Helped
48029
Points
251
Step 1: To turn off the hover option on your Windows 7 laptop, click your Start button (bottom left of your screen), then type main.cpl in the search box and click Enter on your keyboard. You can also go to your Control Panel, click Hardware and Sound, then choose Mouse beneath Devices and Printers.
Step 2: When the Mouse Properties box opens for your trackpad, choose the Device Settings tab to the far right, then click the Settings button below Devices.
Step 3: Double-click the word Tapping (or click the plus sign in front of Tapping once) in the list to the left, then uncheck Enable Tapping. Click OK for both boxes, and you're done. Now you can click when YOU want to click, not when your mouse decides to.
Trying to move files from smart tab to SD card. Tells me to open contextual menu. Can't figure out how to find what I need
Try this steps:
From a Home screen, navigate: Apps > My Files.
Select an option (e.g., images, Audio, etc.).
Tap the Menu icon (upper-right).
Tap Select then select (check) the desired file(s).
Tap the Menu icon.
Tap Move.
Tap SD / Memory Card.
Mar 06, 2019 • Cell Phones
tip
How to Mute Sounds Using Your Hand on the Samsung Galaxy S4
1) Go to the Settings app. Look for the gear icon and tap it.
2) Tap on the "My device" tab at the top to access your device settings.
3) Scroll down with your finger and tap on "Motions and gestures". It should be under the "Input and control" section.
4) Tap on "Palm motion". If it's not already done, activate the feature by sliding the switch until it turns green, first.
5) Activate the "Mute/Pause" feature by sliding the switch.
  • Optional: If you'd like, you can play the tutorial by tapping the text.
on Jan 10, 2015 • Samsung GALAXY S4
tip
Boost your computer performance
<p><span> <p>Your computer's performance mainly depends on the "Processor" and "RAM" availability. I am sure that whatever computer you have is capable enough to run your normal daily tasks smoothly. It should not stuck or freeze while checking emails, writing documents, watching movies or songs, printing or doing business online. These are some very basic tasks and require minimum resources to execute. Any computer with a normal system configuration should work them out easily, but we still face sluggish performance or freezing up while doing these tasks.<br /> <p> The reason behind this is the processor and memory status of your computer at that time. You can check the real time status from "Task manager" which you can pull up by pressing "Ctrl + Shift + Esc" key on keyboard. Following steps would optimize the processor and memory uses of your computer and make it more efficient:<br /> <p><br /> <p>&middot; Check running processes at background:<br /> <p>Every application we use has several processes running in background to make it work. Sometimes we are not even aware of the extra unwanted software or applications which start automatically and keep running in background and eat up our processor and memory usage. This you can check by Task manager's "processes" list. Also some of these applications show their notification icons in "system tray" area which is where you see the system time on your desktop. Try to keep minimum application running in background and this will make our system smooth as it will have more resources to utilize.<br /> <p>Follow the below steps to disable unwanted applications:<br /> <p>1. Click on "start", click on "run" or press "Flag key + R" from keyboard. Type" msconfig" on the "run" window and hit "enter".<br /> <p>2. This should bring "system configuration utility" windows on screen.<br /> <p>3. Click on the "startup" TAB on the top menu. This tab holds all applications which start automatically when you turn on your computer.<br /> <p>4. Check the list carefully and uncheck the ones you don't need.<br /> <p>5. If you are not sure about some application, type its name in google search, figure out its use and decide to whether you want to keep it running or disable it.<br /> <p>6. Once you are done with the List, click on "Services "tab on top.<br /> <p>7. This "services" tab holds all important programs which give a platform for other software to work.<br /> <p>8. Check the box in bottom which says "Hide all Microsoft services".<br /> <p>9. Now you have the list of non-Microsoft programs running in background. Some of these might be you antivirus software, backup software or messengers and others may be unwanted ones.<br /> <p>10. Identify the not required items and uncheck them.<br /> <p>11. Click on "Apply" and then "OK".'<br /> <p>12. It might give you a windows asking for "restart computer" or "Exit without restart ".<br /> <p>13. Choose "Exit without restart"<br /> <p>14. Close all other windows make sure none of you important files are open and then restart your computer.<br /> <p>15. If later you want to enable any services back, just follow the same process and "Check" them in the list.<br /> <p> <br /> <p>&middot; Keep track of free disk space on root drive:<br /> <p>Free space on root drive (mostly c :\) is very important as this space is used for virtual memory or paging, hibernation and other system requirements. Ensure that at least 3 - 5 GB space should be available on root drive. If you have less than this, delete some temporary or junk files from "temp" and "%temp%" folders.<br /></span><br />
on Jul 19, 2011 • Computers & Internet
2answers
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
2answers
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
1helpful
My acer note book stratup very slow and drive not read program. what can i do this problem
Just perform the following steps:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the last month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Click on Next and System Restore will start and windows will take a reboot.
Now Goto Strart and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'Sys config utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
goto 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications .
right click on each applicaion and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
After reboot your problem should be resolved.
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
21helpful
I want bpl wap settings for my windows mobile htc p3400i.
SETTINGS FOR BPL WAP ON HTC P3400
SETTINGS FOR BPL WAP ON HTC P3400I
START>>SETTINGS>>under CONNECTONS tab>>CONNECTIONS>>UNDER ADVANCED tab>>SELECT NETWORK>>select MY ISP there>>then NEW>>
"enter name for these settings:BPLWAP if this exist den BPLWAP2
under MODEM tab create NEW
"enter name for connection:BPLWAP
"selest modem:CELLULAR LINE(GPRS)
tap next
"access pont name:MIZONE
tap next
USERNAME:ur 10 digit mobile no.
PASSWORD:bplmmsc
tap finish
under PROXY SETTINGS tab
mark all two boxes
enter proxy server as "10.0.0.10"
den tap ADVANCED
tap on HTTP
server:10.0.0.10
port:9401
username:ur 10 digit mobile no.
password:bplmmsc
click on ok again ok nd again ok
now below screen will appear saying
programs that automatically connect to the internet shud connect using:select BPLWAP or BPLWAP2
thats it ur done woth settngs
now go tasks der it will show BPLWAP
select MANAGE EXISTING CONNECTIONS
tap and hold on BPLWAP and choose connect
1helpful
Dell C640 change touchpad settings
All,
I read on this a while then found these 2 packages and downloaded from DELL's site:
R49155.EXE
R46325.EXE
I installed the R49155.EXE and got 2 more tabs in the properties window for my mouse (Start + Control Panel + Mouse).
In the new "Device Settings" tab I can either totally disable the touchpad or in "Settings", just disable the "TAP to click"; which is the feature causing the cursor to bounce all over.
Also in the active application section of the launch bar, lower right next to clock, an ICON is now present and "TAP to click" is an option, which I can now easily inable/disable; after opening the ICON with a click.
As I understand it, R46325.EXE is the R49155.EXE on steroids, but did not need that.
Cheers!
OMR
Turn off the modem speaker
To mute the MobilePro 900’s speaker volume, do the following: NOTE: This procedure will have to be performed for all existing and future dial-up connections. * 1. Open Remote Networking by tapping “Start” ? “Programs” ? “Communications” ? “Remote Networking.” * 2. Highlight your dialup connection by tapping it once. Tap “File” ? “Properties.” * 3. Tap the "Configure" button. * 4. Tap the "Call Options" tab. * 5. Enter "M0" in the "Extra Settings" box. (This is capital letter followed by the number zero without any spaces or quotation marks.) * 6. Tap “OK” to close the device properties window. * 7. Tap “Next” and then “Finish” to complete the Dial-up Connection wizard.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
