This will be a blockage in the waste pump or piping, have you lost any small piece of clothing? because its likely to be a samll sock or something thats managed to get past the outer drum seal and get into the waste pump. Not really for DIY but if you want let me know the make and model and I will try to explain the process of removing and checking the pump
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
