Washer will fill with water for washing wont fill for rinse cycle and does not cycle to wash or spin
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
SOURCE: When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
SOURCE: Washer won't spin or drain
The problem is most likely the lid switch assembly. The lid switch is a safety feature that will **t allow the washer to go into the spin cycle unless the lid is shut (so ** wandering children get caught inside).
If the switch is working, you should hear a click when the door closes and makes contact with it. If the lid switch is defective/broken, the washing machine usually won't drain or spin. If it's bad, you will need to replace it. It should be mounted inside of the cabinet, just under the door of the washer (on most models). Please let me k**w if this corrects your problem.
SOURCE: my haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
thats just great i called cusotmer service and they are sending out a repair man this week hopefully its nothing major the washer is brande new and hasnt even been used yet just got it yesterday
Best wishes!
