Hello there and thank you for choosing fixya In Stock
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60
Quantity:
Hi thank you for your reply.I supplied power to the inlet valve indepently and the water came in when I shut off the power to the valve the water stopped.I believe that the inlet valve is ok.Could the water flow meter cause the pulsing problem or is it one of the control board. Thank You.IX D
Whirlpool ADG 6340 Dishwasher
Whirlpoo ADG 6340 dishwasher ,
the overfill pipe is is putting out a lot of water during the wash cycle , i measured about 3 1/4 pints ( 1.85 litres )
what would be the cause of this,
