Heating & Cooling Logo
Posted on Jun 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a York furnace/air conditioning system. When it is set "on", the blower will occasionally stop and bang, bang, bang...try to start...bang, bang, bang...try to start, etc until it eventually gets running again. What could be the problem?
Michael Ulch
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Jun 05, 2011
Michael Ulch
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
16694
Points
134
Blower cage is off balance more then likely. Cage needs to be replaced if this is the case.
3answers
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
York 80 furnance model P3HUB12N08001A curcuit board light blinks 4 times. What does this mean?
Check on the back of the bottom blower cover...I think it is either pressure switch or high limit...
But the codes are always listed on that bottom cover on the inside...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
1helpful
3answers
My York furnace is giving the error message for "rollout switch open"...when it does that, the flame does not ignite and the fan blows cool air. However, if I remove the panel from the furnace,...
Roll out switches are sometime wired together with limits. Lack of air flow. Limits reset themselves and roll outs have to be manually reseted. Could be dirty blower,a.c. coil on furnace, or filter.
3helpful
Can I convert a propane furnace to electric?
Actually yes! You can install electric elements in the plenum that turn on by your thermostat. The convection blower from the furnace can be used. You can also install a heat pump system that will give you both heat and air conditioning.
The furnace attempt to light, you can see the
The flame sensor is not sensing the flame. Google "flame sensor"
May be an adjustment or control board problem.
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
My condensor is frozen and the furnace fan is humming
you have a bad fan, or something stopping it
your coilsd arfe frosted over becuase they are not getting propper air flow across them
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Top Heating & Cooling Experts
Paul Carew
john h
