My Miller gas furnace occasionally stops in mid cycle, the ignitor works, gas starts up blue, just as it starts blowing it goes ''poof'' and shuts off, but the fan keeps blowing for a few minutes. It is getting worse. lately it has also started up again immediately after a successful cycle ends (Like the fan will shut off as usual, and then click, it starts up again....Help?
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.
Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Please leave feedback... Thanks...
1.
2.
3.
closes.
4.
ignitor closely for cracks. Make sure you do not
limit, rollout switch problem. The furnace's control board
might not be supplying the voltage to the ignitor.If your furnace
gas.
Solution: You
inspect your ignitor closely for cracks. Make sure
problem or a limit, rollout switch problem. The furnace's
Thank you , but No, the flame stays consistant, I checked, The problem is intermittent, but happens at least once a day. If I "reset" the thrermostat by turning it off, moving the temp dial up and down and then setting on 70 again, then it usually works fine for the next several cycles. However I usually awake (The coldest hours of the morning) to hear it miscyclingg again..
UPDATE" The fast cycling has been solved with new filters (I know... I know :-(), but the intermittent shutting off right when the blower starts is still happening.
