I have a new hoover steamvac spin scrub. This was the third time I used it in the past ten days. I changed the water and added cleaning solution and when I turned it on it made a weird sound and died. It will not turn on at all. I tried another outlet and still nothing. It had a faint hint of a burning smell at first. Could it have overheated? I had been using it for about two hours.
Re: I have a new hoover steamvac spin scrub. This was...
It sounds as if this machine has a defective motor. Usually a bad motor will fail quickly. You should have a 1 year warranty, so I suggest looking on Hoover's website for an authorized service center.
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
The brushes are turning by an air driven turbine. The turbine has a
pivot bushing made of steel inside of it that gets rusty because of the
water that is running through it. The turbine gear will have to be
replaced.
You can access the turbine gear by removing the hood. You can find a
genuine hoover replacement part by following the link
below. Just find the model number of your Steamvac.
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
http://www.hoover.com/pdfs/manuals/F5914900.pdf here is the manual for your model try cleaning the vent inside the plastic container in the front of the machine if its new you may still be under warrenty and contact info for that is on the site above as well!
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
