SOURCE: I can not get my phone to pick up on the answering system when a caller is trying to leave a message
Did that too! Thanks. I think I need to call the phone company to deactivatge the generic meesage system that keeps picking up before the answering machine for the new phone we just bought.
SOURCE: inaudible announcement
How close were you to the base unit when you recorded the message? The manual suggests 9 inches from your mouth to the mic on the unit. Also speak loudly when you make the recording. Yes, you can re-record the message. In fact, you can record two messages and use whichever one fits your immediate circumstances.
SOURCE: Panasonic KX-TG5673PK 5.8ghz phones.This post
answering from hell?? is that the message stored ??
this seems like a corrupted phone software
SOURCE: GE model 25881 5.8 GHz dual handset phone
DON'T hold the memo key. Use the book for set up instructions. Took me about 6 times to figure this out!
SOURCE: New GE Model 28821 Answering System HANGS UP after greeting announcement! HELP?! ;P
JUNK IT AND GET A PANASONIC.. THATS WHAT I DID. THIS GE PHONE IS THE WORST.
These steps worked in MFC620CN/420CN/410CN/210C/240C and FAX2440C model.
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
enjoy & cheers
