Question about GE 28112EE2 Cordless Phone
Inaudible announcement GE Model 28112 DECT 6.0 outgoing announcement inaudible. Can I make it louder?
Posted by Forestbird on
Anonymous
    Problem Solver:
  • 15 Answers
How close were you to the base unit when you recorded the message? The manual suggests 9 inches from your mouth to the mic on the unit. Also speak loudly when you make the recording. Yes, you can re-record the message. In fact, you can record two messages and use whichever one fits your immediate circumstances.
Posted on Dec 29, 2007
Need an instruction mnual for GE 28112EE3-A Dect 6.0
Thomson built the 28112 Expandable DECT 6.0 phone for GE. They have the manual available on their support site: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
I hope this helps.
Jan 10, 2012 | Lands Phones
HAVE GE PHONES MODEL NO. 25942J-3C, SERIAL NO. 90557643. HAVE LOST MY USER MANUAL AND NEED TO CHANGE MY ANSWERING MACHINE MESSAGE AND CAN'T REMEMBER HOW TO DO SO. HELP.
Here is the answer from the User Guide found on the manufacturers website. for more help go to http://www.home-electronics.net/ge/pc/IB/25942EE1_IB.pdf
Recording the Outgoing Announcement
For best results when recording, you should be about nine inches from the microphone,
and eliminate as much background noise as possible.
1. Make sure the answering system is On2. Press and hold the announce button on the base.
3. Begin speaking after you hear the beep.
4. Release the button when you finish your announcement.
NOTE: If you choose not to record an outgoing announcement, a default
announcement plays instead. To return to the default announcement after
you have recorded your own outgoing announcement, press the announce
button and release it when you hear the beep.
Sample Outgoing Announcement
"Hi, this is (use your name here), I can't answer the phone right now, so
please leave your name, number and a brief message after the tone, and
I'll get back to you. Th anks.
Sep 01, 2011 | GE Lands Phones
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: http://att.vtp-media.com/ecp/documents/product_Product/132/UserManual/5995/cl82509_manual_USA_i6.pdf . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: http://telephones.att.com/att/index.cfm/product-support/manuals/ .
I hope this helps.
Apr 01, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you change the message on my GE 28821FE2-A cordless phone?
1. Make sure the answering system is ON. 2 . Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“. 3 . Begin speaking after you hear the beep. 4 . Release the button when you finish your announcement. NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing. Sample Outgoing Announcement Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks. NOTE: The maximum recording time for the outgoing announcement is 2 minutes. Reviewing and Choosing the Announcement Press and release the announce button to review and select this one as your outgoing announcement. NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
Mar 25, 2009 | General Electric 28821FE2 Phone
Ge cordless Model 28112 6.0
I found out that I needed to puch the program button. the manual was not clear on this.
Thanks
Apr 02, 2008 | Lands Phones
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
Would like to record greeting
Here is a link to the instruction manual (5.06MB): http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2. Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep. Sample Outgoing Announcement Hi, this is (use your name here), I can?t answer the phone right now, so please leave your name, number and a brief message after the tone, and I?ll get back to you. Thanks. Reviewing Announcement ? Press and release the announce button to play your outgoing announcement.
Mar 04, 2007 | GE 25881EE3 Phone
GE 28112EE2 Cordless Phone Logo
88 people viewed this question
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
