HP Officejet J5780 All-In-One InkJet Printer Logo
Posted on Apr 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot scan using hp officejet j5783 all in one message reads "the scanning software could not be found, or your scanner is not connected. Make sure your scanner and scanning software are properly connected" Kobus
IT Solution
Level 3:
  • Master 805 Answers
  • Posted on Apr 18, 2011
IT Solution
Master
Level 3:
Answers
805
Questions
Helped
156569
Points
2358
Thank Dear, I got your answer.
First, if in your computer install previous scanner driver then first uninstall it after doing that please restart your computer.
2nd, connected your device with computer and insert its driver software in CD ROM. After sometimes you will watch the new window where shows device has found and install your driver. When you watch it then click next and install your driver.
3rd, Restart your computer
It become okay in stead of other major fault in your device.
Thanks
2answers
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
2answers
Hp officejet j5780, NOT SCANNING
go to www.hp.com and download a new driver of your scaner for xp
5helpful
3answers
The scanner dont work in my HP officejet 5610 all in one
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ... HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
4helpful
2answers
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
k24674
Grand Canyon Tech
Grand Canyon Tech
