Vacuums Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Kirby Heritage II vacuum. Need to replace a split fill tube. How do I remove the outer cloth bag from the mini-emptor, and then how do I take off the old/attach a new fill tube?
Marci Marple
Level 2:
  • Expert 357 Answers
  • Posted on May 10, 2012
Marci Marple
Expert
Level 2:
Answers
357
Questions
Helped
172230
Points
543
Anonymous
Level 2:
  • Expert 240 Answers
  • Posted on Apr 16, 2011
Anonymous
Expert
Level 2:
Answers
240
Questions
0
Helped
69620
Points
512
There is no need to remove the outer bag. The fill tube can be removed by cutting it off near the bottom and pulling on the support wire to unwind it from the neck on the mini-emptor. I usually hose down the bag and slosh it around in my laundry sink to clean it. After it dries, the new fill tube can be screwed onto the mini-emptor. You can wet the bottom of the tube with plain water to make it go on more easily. If you screw it on firmly, there is no need for cable ties at the bottom. Re-attach the top adaptor ( bag holder ), and secure it with cable ties.
1helpful
I have a Kirby Heritage II Turbo and I need a user's manual, but can't find one anywhere. I have to replace the fill tube in the bag and can see the cable tie on top that holds it in place, but don't know...
Taping usually just causes a mess. The mini-emptor has coarse threads on it that the fill tube screws on to. Occasionally there is a cable tie on the bottom which is not really necessary. If you cut the tube near the bottom, you can get hold of it's wire frame and rip it out. After cleaning the threaded area on the mini-emptor, wet one end of the new fill tube with water and screw it well down. The bag top adapter can then be put on and secured with cable ties.
1helpful
2answers
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
1helpful
2answers
I need to install a mini emptor on a Heritage II Kirby
I actually figured this out on my own. Just removed the rubber out seal between the bad and em-tor, then used a screw driver to gently pry the bag out of it's grove. The wire part of the hose actually unscrews from the em-tor. Reverse the process to install the new one. Gotta love Kirby engineering.
2answers
Dust smell when running g4 kirby
The dusty smell coming from my G4 finally drove me to search out the problem. As it turned out, the fill tube had cracked near the top of the mini emptor (the boot) and dust and crumbs were escaping from the tube and into the cloth bag. I tried to repair the split with duct tape and electrical tape, but to no avail. I finally gave up and ordered a new fill tube online for about $8. This took care of the problem, and the machine works like new with no more dusty smell.
2answers
How to change Mini Em-Tor Fill Tube Assembly on Kirby G4
You will have to remove bag strap. You can try to save old strap (see instruction here) or you can cut it. Install the bag on the new mini-emptor just like it was on old one (strap goes over both layers of vinyl). Use a long cable tie instead of the strap if you have damages it or your old bag strap. If you are using old strap you may have to use pliers to get it in all the way.
2helpful
2answers
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Do you know how to change a emptor assembly
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725050 Generic problem for all Vacuums… Do you know how to change an emptor assembly? Posted by smcgee on June 30, 2008 I've got a Kirby G4 and I need to replace the emptor assembly. Do you know how to change it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby mini emptor assm can be replaced by going inside of the cloth bag and looking for the ty tie that is hold it onto the clothe outer bag and cut the ty tie to release the mini emptor on the Kirby. The bag @ the bottom has elastic around the bottom and should come right off; it will be tight but should come off. The front of the mini emptor has a gasket so make sure the new one has the same small gasket also, and that will just turn and unhook. You need to find a new ty tie just as long as the one you are removing; either from a local vacuum cleaner store, the Kirby Factory Cust serv (Parts) or try the Home Depot or Menards or a box store similar to those. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – U. S. & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 • Vacuums
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
