Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Step 1 Swipe the Status bar at the top of the screen towards the bottom of the screen to display the Quick Settings menu, and then tap "More." To open the Quick Settings menu in Explore by Touch mode, use two fingers to swipe down the Status bar. Step 2 Tap "Accessibility" to view all settings related to accessibility. Locate the Text-to-Speech and Voice Guide options in the menu. Step 3 Turn off the "Text-to-Speech" and "Voice Guide" options to disable the voice capabilities of your Kindle Fire HD.
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected
to your CPU, then depending on your keyboard model, you may have to
turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
While in browser, open settings (bottom left button) and change display setting. The s3 has separate display settings for browser and general phone. Hope this helps.
