Dell DJ MP3 Player Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Dj version 1.00.03 so i cant find my dell dj program disc and i am having trouble connect my Dell Dj to my laptop .... the usb pick it up but it keeps asking for the driver which i no longer have ... can someone please help
Manolito Mendoza
Level 2:
Sergeant:
  • Expert 236 Answers
  • Posted on Mar 13, 2011
Manolito Mendoza
Expert
Level 2:
Sergeant:
Answers
236
Questions
0
Helped
70630
Points
713
As you have described that you need a driver for your Dell DJ, you may download either Dell DJ (Gen 2), v.1.01.01, A01 or Dell DJ (Gen 2), v.1.00.03, A00. Both versions are compatible with Windows 2000 and XP. Click on download and follow the procedures. Keep in mind that versions of softwares and drivers are limited from manufacturer's releases.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
My computer does not recognize that my dell dj is plugged in when using yahoo music jukebox. When I try to transfer music from the computer to the dj, it tells me "no device connected".
Originally Posted by gb07 from another site
"The solution, was to uninstall Windows media player. The first uninstall only let it roll back to version 9(the original version on my computer; yours may be different.) Then I went into control panel and removed it from my windows media components. Then, I went to the folder c:programfiles/dell/digitaljukeboxdrivers. There is a program in there called drvunins. I started it, and it removed all drivers for my dell dj. I then made sure the dj was unplugged. Restarted the computer, then I then downloaded the latest dell firmware, v. 2.20.07.
Found here-
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107735&SystemID=PDA_MP3_DJ_2&servicetag=&os=WW1&osl=en&deviceid=9420&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=31&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=139674
FINALLY, after all that, it did in fact connect, and load the firmware successfully."
I can confirm this does work mine is now working perfectly!!
Dell Dj version 1.00.03 so i just moved and
Visit http://support.dell.com . You may find the required program from there.
2helpful
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
2helpful
4answers
Dell Pocket DJ 5gb music problem
i need a drivers for my pocket dell dj 5GB model number HV03T
Dell dj computer saysn= not connected
What operating system is your computer? If it is Vista you will have trouble getting your dj to work. Dell dj software was meant to be used with XP or Windows 2000. If you are currently using either one of these two Operating Systems then you most likely have a driver problem. The best solution is to install a software package from Dell, labeled R74224. This package includes the driver and Musicmatch software.
Dell dj firmware
I had the same problem and it turns out the firmware did get loaded, the program just didn't close out properly. If you go to Settings & Info-->Information on your DJ you should see that it is the updated version.
9helpful
5answers
Dell DJ Gen 2 Won't connect
if your Dell DJ player is no longer recognized by the upgrade firmware even with the correct, original device driver installed, then you will need to install a windows 'MTP' driver by doing the following. Note that this applies to Windows XP only.
1. make sure you have the SP2 XP upgrade.
2. Install Windows Media Player 10 or roll it back to version 10 if you are using a later version. You can roll it back by going to 'Add or Remove programs' and uninstalling any WMP upgrade from the 'Change or Remove Programs' dialog window. Note: don't uninstall WMP enitrely from the 'Add/remove windows components' dialog.
3. Go get this file: fixup.zip Unzip it in a temporary directory and run the fixup.cmd by double-clicking in explorer or using the windows 'Run' command. Follow the instructions it prints in its DOS window about deleting the Dell device in the hardware manager.
4. plug your DJ player into the USB port. XP should now say 'Found MTP device' or something similar.
5. Get the Dell DJ 1.02 firmware from their support site appropriate for your player. Run the firmware upgrade. The software should detect your player this time.
A good reference for the Dell DJ stuff is here: gotzune.com
Note: I can't personally recommend the 'PlayForSure' firmware as I have not been successful upgrading to it. WMP 11 does not seem to work with the Dell DJ but WMP10 does and the device Sync function works just fine.
For almost ALL of the MP3 players out there that seem bricked due to a firmware upgrade failure or some other reason, they can be usually restored in a simlar way by installing a basic 'MTP' driver which allows windows to at least send a file to it, and by putting the player into a recovery mode as defined by the manufacturer.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
