Televison & Video Logo
Martin Giorgi Posted on Mar 03, 2011
How to program for sat - Televison & Video
burnsmatt86
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Mar 03, 2011
burnsmatt86
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
4236
Points
57
You do not need to program the TV for SAT because your signal comes directly from the SAT, you are only using your TV as a monitor, not a tuner. Connect your SAT via standard rca, component, or hdmi cable and change the input on your TV to the same input that you have connected your SAT to. If you connect via coax cable then set your TV to channel 3 or 4, ALWAYS using your SAT remote to change channels for both options.
No remote. How do I reset the menu or channel programming? Using sat box, but can't get the TV to channel 3.
You best bet really is to locate an original and not a universal remote for the set
1helpful
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help...
the sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
4helpful
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
I need the directions on how to set it up.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Repeat the process with the CBL/SAT button to program for your sat box.
Hope that helps.
Vaio sat survey has stopped working
VAIO sat survey is not an important program. Usually you will get it if the first time you turn on the computer and set it up. If you encounter that type of problem, you can uninstall it from the programs list of the system
  1. start menu
  2. control panel
  3. programs and feature
  4. look for vaio surevey and uninstall it
  5. restart the computer
that should resovle the problem
34helpful
5answers
Vaio Care & Vaio Sat Survey.exe has stopped working
Hi guys. I'm a Technical Support Agent for the Sony VAIO.
Please open the C: Drive > Programs x86 Folder > Sony > satsurvey or survey, then, delete the vaiosatsurvey.exe File from there. It should successfully resolve the issue. Hope it helps. I took remote sessions and resolbved many issues.
R30
Program bell sat remote for insigna tv
where can I find a manual for a Daewoo model DV-T5DN
Sanyo VCR - further info required
Hi, as stated on other post, VCR cannot be programmed storing sat channels in memory, you can get only a unique sat input channel on VCR.
You can only record from the channel that is currently been received on Sat, you can even use VCR timer, but you cannot store Sat channels into VCR.
all you do is connecting the sat box output to VCR, and VCR will see the SAT box as input, or line 1, or AV1, or external, or something similar, depending on the model.
You cannot program VCR on sat channel, you will need to leave sat box on the channel you want to record, it will be the same on a DVD RW.
Regards
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
