Question about Sony VAIO VGN-CS118E/P NoteBook
Vaio Care & Vaio Sat Survey.exe has stopped working
HI vaio care& sat has stopped I am receiving these two error messages when I start up my computer, saying that "a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is availabl
please keep any responses "user friendly".
Thanks for your help.
Posted by amerosman922 on
Anonymous
    New Friend:
Hi guys. I'm a Technical Support Agent for the Sony VAIO.
Please open the C: Drive > Programs x86 Folder > Sony > satsurvey or survey, then, delete the vaiosatsurvey.exe File from there. It should successfully resolve the issue. Hope it helps. I took remote sessions and resolbved many issues.
R30
Posted on May 27, 2010
  • Nagaraj R
    Nagaraj R Feb 25, 2011
    I have performed the steps as mentioned above..... please give a try... it will resolve the issue for sure..... I bet if any don't get the issue resolved.....
  • iqbal
    iqbal Jun 26, 2014
    thanks
Anonymous
  • 3 Answers
Hi there ! I had the same problem and solved it changing the date format in Regional Settings to an english format. I used mm/dd/yyyy and now the vaio programs work ok.
Posted on Sep 25, 2009
Anonymous
HI vaio care& sat has stopped I am receiving these two error messages when I start up my computer, saying that "a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is availabl please keep any responses "user
Posted on Jul 18, 2009
Anonymous
Hello, I receive an error when I open my computer. It says "vaio sat survey.exe has stop working.. Windows is looking for solutions". I don't know how to fix this. Maybe you can help me, please. Thank you
Posted on Apr 15, 2010
  • Anonymous Nov 11, 2016
    Thanks Man...It's Worked for Me ....
Anonymous
    New Friend:
I had the same problem. Go to sony.com and look for the chat support. It took less than 2 minutes and they solved it.
Posted on Apr 23, 2010
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: vaio care, vaio sat survey and vaio luncher have been stopped wor
I had the same problem , i was using a spanish date format.
I changed the date format to an english format (mm/dd/yyyy) and now all vaio programs work ok at start up and afterwards.
Vaic t200 password needed to unlock but none offered. please help
Hi! Welcome to www.fixya.com.
Recover From Within Windows 71Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
2Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
3Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased. The computer will restart and the recovery process will begin. When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition1Turn on or restart your Sony Vaio computer.
2Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine. If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
3Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter." The VAIO Care program will appear on your screen. Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs1Insert the first recovery disc in your optical drive and restart your Sony Vaio computer. The total number of recovery discs varies based on your Sony Vaio computer. The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
2Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
3Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
4Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete. The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system.
Read more: How to Recover Factory Settings on Sony Vaio Computer with Windows 7 ' eHow.com http://www.ehow.com/how_7680511_recover-vaio-computer-windows-7.html#ixzz1SY1sA7Sg
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Computers & Internet
Open Run window by pressing the Windows logo key+R key together.
Then, type "msconfig" in the run window.
Then, click on startup tab.
Click to uncheck the VAIO Survey option. Click on apply and OK.
Stop the Oasis2.exe services.
In Run window, type "services.msc" and locate the oasis2.exe services and stop them.
This will resolve the error of VAIO Sat Survey.
If issue persists, uninstall the VAIO Sat Survey or VAIO Survey software.
Click on start>Control Panel>Programs and features>programs>Uninstall a program>Application Manager for VAIO>VAIO Survey/VAIO Sat Survey-Uninstall.
Restart the computer.
May 28, 2011 | Sony VAIO VGN-CS118E/P NoteBook
Why does my computer show message below: "VAIO sat survey.exe has stopped working" What should I do?
Vaio Sat Survey was a bit of software that Sony installed for the express purpose of them getting feedback from their users..
There are a few ways to get rid of it, you do not need it and it won't damage your laptop ro dispose of it
1.) In control panel, go to programme control and locate the Vaio cat survey programme, delete it (sometimes it cannot be found there, so proceed to the next step)
2.) Open the C: Drive / Programs x86 Folder / Sony / Satsurvey or Survey, then, delete the vaiosatsurvey.exe File
Dec 31, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Sep 04, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Vaio sat survey not working
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Vaio Sat Survey exe.has stopped working. Pls help me with another or what must to do to fix this problem
This isn't really a necessary program; unless you want to answer Sony's questions they may have for you from time-to-time. It's what it says it is, a Survey program. You can go to Control Panel and remove it from your computer. That should fix the problem. Start Button\Control Panel\Programs & Features (Add & Remove programs), then find the Survey program and uninstall\remove it. Then reboot your computer. That should fix the problem. madhattercomputers.com
Mar 14, 2010 | Sony VAIO VGN-CS118E/P NoteBook
I keep getting the message "vaio sat survey.exe" stopped working
run type msconfig inter
startup uncheck this message apply ok restart
seeeeeeeeee
Jan 26, 2010 | Computers & Internet
Vaio care, vaio sat survey and vaio luncher have been stopped wor
Sep 21, 2009 | Sony VAIO VGN-CS118E/P NoteBook
How to get ride of the message ''Vaio Sat Survey.exe has stopped working''message onn my new VGN-NW120J
See this forum post. or this one.
You can uninstall the Vaio VSC Vaio survey program from the control panel>programs & features list. If you want to keep the survey program sony put on your system, but don't want it to run, remove it from the startup list.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 02, 2009 | Sony VAIO VGN-N130G/W Notebook
How do I get ride of the message: "Vaio Sat Survey.exe has stopped working" on my new VGN-NW 120J
Hi There !!
Thank you for writing to Fixya.com
The Sony Vaio softwares are not updated correctly, That's the reason it might be crashing, on the other hand you always need to consider the Windows Update as well. My suggestion would be:
  1. Click Start
    vistastartbutton.jpg in the Start Search box.
  2. Type msconfig, and then press ENTER.
    securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  3. Click the Startup tab, and then unchecked the Vaio Sat Survey.exe, if you find it.These are software that Computer Manfacturer installs on your system initially & they rarely good for the users.
Now after that, Go to windows update & perform the Windows Update.
Need help with windows update, check the link below.
http://www.microsoft.com/windows/downloads/windowsupdate/learn/windowsvista.mspx
After installing all the latest updates, Restart the machine.
Hope this will help.
Sep 02, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Sony VAIO VGN-CS118E/P NoteBook Logo
9,950 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
