Kodak EasyShare M575 Digital Camera Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera will not close it's lenses what do i do
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Feb 25, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524308
Points
8345
Remove battery and card, insert battery and as it tries to retract hold edge of lens firmly and try to help it retract by moving it quickly and slightly from side to side. There may be grit or the gearing has jumped a tooth and this sometimes works to help it back into place. Don't over force it.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
1helpful
My samsung S1050 lense will not open or close, it is stuck half way.
forcing it closed usually ends badly...stripped or sheered gears.TRY putting pressure on the lense durring power up...if it feels like it will move let it go....next using a small jewelers screw driver try to pull the lense open ...may take a bit of playing...be patient!
What lense can i use for close-up shots
That would depend on the camera, but I'm going to assume you have one with interchangeable lenses.
The camera manufacturer probably makes one or more "macro" or "close-up" lenses for your camera. Any of these lenses will let you get closer than a normal lens. Many third-party lens makers also make macro lenses.
Another alternative is to put extension tubes between the lens and the camera body. This moves the lens further from the camera, shortening the focus distance.
Probably the cheapest (and lowest quality) alternative is to put close-up lenses on the front of any lenses you already own. These screw on to the front of the lens like a filter and act like a magnifying lens, letting you get closer to the subject.
The camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
My camera won't focus when I'm trying to take a picture of something close up.
Try taking pictures of close-ups at 14mm setting on 14-42mm or buy the close-up lens that you can use on the filter ring of your zoom lenses lenses.
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5helpful
2answers
Turn the power off and on again
1helpful
Lens keep extended in an out
3helpful
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Camera will shut off then the shutter will close
Yes it could. It is possible a small dirt get on the side of the lense and it prevents the lense to close all the way in. Clean it up and while turning the camera off, push the lense in. Not too hard. You might have to repeat the step a few times. Do not drop your camera, if you did make sure you clean the sides of the popped off lense. If they did not help, some mechanical part of the lense is shifted or broken.
Good Luck
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
