Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses Logo
Question about Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses
My camera won't focus when I'm trying to take a picture of something close up.
Posted by imbos on
Anonymous
    New Friend:
  • 55 Answers
Try taking pictures of close-ups at 14mm setting on 14-42mm or buy the close-up lens that you can use on the filter ring of your zoom lenses lenses.
Posted on Jun 17, 2010
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 • Cameras
1helpful
I just bought a canon rebel xt and I have been playing around with settings I am very new to photography. As of right now when I try to take the shot the flash keeps blinking and its says busy and it wont...
It sounds like you might be too close to whatever it is you're trying to take a picture of. Each camera lens has a minimum focus distance listed on it that determines how close you can get to something and still take a picture. Page 45 of the XTi manual talks about minimum focusing distance and describes the camera's behavior.
It's also possible that there is not enough light for the lens to focus. In this situation you might have to flip the switch on the lens to manual focus to take your picture.
So, either try moving further away so the lens can focus or use the manual focus.
In case you are interested, here is a website that discusses the minimum focus distance. Even though the website talks about Nikon cameras you will still be able to use the information.
Also, on page 160 of the XTi manual there is a section titled "When Autofocus Fails" that will give you an idea of what your camera is doing.
Cheers and good luck. :)
Since dropping my Tamron 70-200 lense, it continues to work, but the autofocus is just off. The camera will focus on the subject and take the photo, but when reviewing the photograph it is out of focus....
Hum, something doesn't sit right with what you just described. If the camera in focus green dot comes on solid then the camera is saying the image is in focus. Did you just drop the lens or was the camera attached to the lens and the whole assembly hit the ground. Lets back up some more what is it you are trying to focus on, meaning the camera will be confused solid colour, no contrast, glass, water, chrome. Or trying to focus on something to close for the lens optics yes I know you said Macro but even macro but even this lens has a minimum focus distance. Check your specification sheet that came with the lens. Okay another thing and this is a biggy if you are trying to focus on something at F2.8 close in the camera may catch focus but the DOF is so shallow you can't actually see the focus point and everything appears out of focus. Okay another thing, lets say you have this lens mounted on a tripod at a setting of F11 and a shutter speed down into the 1/50 or even a bit slower, your think you are okay because it's on a tripod right, nope just by you tripping the shutter you have moved the camera and the pictures will be blurry under close examination. In this case you need to do one of two things or both. You can use a 2 second shutter delay and or mirror lock up. I use both when available. I've even gone to using an electronic release in some cases. So if the camera in focus light in the lower right corner of the viewfinder comes on solid then the camera has focus. If the lens was off a bit the in focus light wouldn't come on or if it did it would flicker and if it's not got focus the shutter couldn't be released. So sorry I think it's one of the other problems I mentioned. Hope I helped and not confused you to here is a sample picture a center crop of a much larger picture the scene was 3/4 mile away.
It's pretty crisp but the sizing took a bit the original you can count the brick on the building.
Picture here
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 • Cameras
Canon Eos Rebel xti won't take a picture when zoomed in
Try a different lens just to check out the lens focus sensor. or put it in manual focus.
Will not focus on close-ups
Check your manual and settings it is likly you have overlooked something.
Have you set it to Macro Mode? the icon is like a flower or plant
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Open Questions:
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
