Saturn is a GM product, take it to any Chevy dealer and they should be able to help you. Although, if the previous owner left the car manual in the glove box then the factory unlock code should be there, unless they previous owner changed the code then the dealer will have to reset it.
you cannot do it yourself,either contact a gm dealer or possibly a tire store-there is a little hand held remote that you have to set up against each individual tire to recalibrate the sensors
I have the same problem, found that when it rains heavy or I wash the Saturn Sky; water runs down over the computer under the hood on the driverside. There is a drain port just above the computer so water runs down through the drain port onto the computer wiring shorting out this computer, when the wiring dries out the electrical problems are fixed. but the water can do damage to the computer which comtrols the radio and many other electronics inthe Saturn Sky. I know this because this happened to me. after washing my Sky all the electronics went crazy, found the water on my computer wiring. after a couple of times of the wiring shorting out the radio started comming on by its self while the car was shut off causing the battery to die over night. What a crazy place to put a drain port over top of a computer and its wiring. A cover needs to be made and placed over the top of the computer to prevent this from happening again. If you are having a problem getting GM to fix the problem; wash the car using a garden hose and let alot of water run down over the window on the driverside so the water can run down the water port under the hood onto the computer and wiring, this should create the same problem then take it back to the GM dealer and show them the water problem. They can then refuse to correct the problem. Good Luck. O yes one other problem you need to know about, if you don't have mud flaps on the front wheels the paint will chip real bad on the rear lower quater pannels and it will cost you a good dollar to have it repainted.
need to take it to dealer to relearn key fob,but they dont lose programming often,prob not working cuz it was dropped and the battery terminal insde broke off and not making contact,,
If it is like most Saturns if you had the radio or any eletrical equipment on when you changed the battery it blows the fuse. It will also blow the fuse to your turn signals or wipers if they are on.
