Polaroid A500 Digital Camera Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After connecting the usb cables and selecting "PC
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 14, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470474
Points
19564
Please do hard reset on your camera by turning it off, removing the battery and get it turn on again. Now paired you camera with computer. If still get problem remove and re install your driver.
Regards
In my phone when i connect my phone(nokia c2-01) with pc with pc suit mode then it display "faild to change usb mode. change usb mode from phone." but in mobile i select pc suit mode what...
In order to change this you have to disconnect the cable and then put it back in with 1mm sticking out as the adaptor inside automatically chooses the recmommened service. Contact me if this doesn't work.
tip
To Connect Your Phone to Your Computer
In today's world we use mobile phones to all the <b>PC connection</b>, connecting the phone to our <b>PC</b>, we can dial your modem and connect to your ISP, intranet or any other network. In most cases, simply connect your phone to your computer, you can use telephones to the network including the Internet, and services.<br /> <br /> Before you begin, it might be a good idea to contact your mobile provider and ask what services you have available, because some providers do not completely block these services, contact information, and you could be (ie, login, password , etc.).<br /> <br /> <b>BlueTooth: "Wireless PC Connections"</b><br /> <br /> After checking with your phone provider to find out what services you have:<br /> Verify that the Blue Tooth is active and detect your mobile device.<br /> <br /> Blue Tooth Open control panel located on your<b> PC</b>.<br /> <br /> On your <b>PC</b>, select "search phone", then select your mobile device and click the button "Pair."<br /> <br /> Enter a "new" password, then enter "same" password on your mobile device when prompted.<br /> <br /> When prompted on the <b>PC</b>, select the connection type and Internet connection information for your wireless service provider or ISP.<br /> <br /> <b>USB: "Data Cable"</b><br /> <br /> Again, after an adjustment for operator services available to you:<br /> <br /> If you have software that works the phone with the software. You may have to skip the rest of these steps.<br /> <br /> Connect the data cable to the back of the phone and the other to a USB port on your<b> PC</b> or <b>laptop</b>.<br /> <br /> If you are prompted to select the "how" to connect.<br /> <br /> If you do not have software installed on your mobile device let your <b>PC</b>, check if it is unable to install the correct driver.<br /> <br /> It may be necessary to access the device from your computer as a "Drive" and then examine it in a folder ..<br /> <br /> As with all the information I can not guarantee the net this article 100% accurate, or even ensure that the information will not destroy the mobile device when you try to attach it to the Internet. This article was meant to be a brief overview of a typical outreach activities.
on Mar 01, 2011 • Computers & Internet
2helpful
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
2helpful
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Can't connect psp 3000 to mac with USB cable
Try reformatting the memory stick. If that does not work he can try to connect just the memory stick it self ( may need an adapter) to the mac and formatting it there. Other wise you may need a driver for the PSP.
5helpful
2answers
Can't download my video files from xacti e2 to my computer
TRANSFERRING RECORDED IMAGES AND VIDEOS FROM YOUR VPCT700 DIGITAL CAMERA TO YOUR COMPUTER
Connecting the Camera to Your Computer
1. Connect one end of the USB cable to the PC/AV terminal of the camera.
2. Connect the other end of the USB cable to an available USB port on your computer.
3. Turn on your camera.
-The [USB] screen appears.
4. Select [PC] with the Up and Down Arrow buttons, and press the SET button.
5. From the Windows desktop, double click on “My Computer”.
6. Look for a new “Removable disk” icon. This “Removable disk” is actually the memory card in your camera. Typically, the camera will be assigned drive letter “E” or higher.
7. Double click on the removable disk and locate the DCIM folder.
8. Double click on the DCIM folder to open it to find more folders.
-Your recorded images and video clips will be inside these folders.
-Copy & Paste or Drag-N-Drop image and video files to a folder on your computer.
Mac users: Double-click the “untitled” or “unlabeled” disk drive icon on our desktop. iPhoto may automatically launch.
Downloading images and Video Files
When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the “Removable disk” (“untitled” or “unlabeled” disk on a Macintosh) to your computer hard drive.
Windows
Open the “removable disk” and subsequent folders by double clicking on them. Your images are inside these folder(s). Select the images that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the camera to a desired location.
Macintosh
Open the “untitled” disk icon, and the destination location on your hard disk. Drag and drop from the camera to the desired destination.
NOTE
- Memory card users may prefer to use a memory card reader (highly Recommended).
- Video playback application is not included with the package. Make sure that video playback application has been installed in your computer.
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
