Question about Polaroid A500 Digital Camera
Time and date
When i turn my camara on the time and data input is the first thing i see. i have reset it and when i take pictures its not the correct data and when i turn my camara off and then back on the time and date input still is the first thing i see.
Posted by alywallace on
  • 2 more comments
  • lailaskye Nov 24, 2007
    i set the date everytime i turn my camera on and wheni turn it off the date changes. i have to set it everytime i turn my camera back on. its the first thing i see when i turn it on.
  • Tweetie0523 Dec 12, 2007
    I have the same problem and would like to know how to fix it. i never had to do this before
  • Anonymous Dec 14, 2007
    Every time I turn my Polaroid A500 on it goes to the date 10/01/03. I'll reset it, but it does save the setting. If I press "ok" after truning the camera on, it clears the date and I can continue taking photos until I turn it off again. Also, the photos I am taking are showing up in random order, never in the order they were taken. All this started at the same time, sometime around 9/2007. Other than this problem, the photos are okay.
  • abt122 Dec 21, 2007
    same problem. when I turn the camera on the first thing that shows up is the date setup. I am getting tired of resetting the date everythime I turn the camera on, it is 01/10/03.
Anonymous
There is a small 3volt battery soldered on the main board that needs to be replaced. It has a yellow band around it, unless you can replace it yourself it's not worthwhile. If you decide to replace it beware of the flash capacitor charge.
AL
Posted on Nov 18, 2008
Anonymous
I fixed the same problem all of you seem to be having with your A500 camera, with no solution from Polaroid (the date setup popping up each time I open my camera and all the photos not being in order) - I pitched it, went out and bought another camera with another name. I gave one to my daughter-in-law and the same thing happened to hers within one week of my problem. Shame on Polaroid for not offering their customers a solution to this problem or compensating us in some way! NO MORE POLAROIDS FOR ME!!!!!!!!!!!!!!!!
Posted on Jan 07, 2008
Anonymous
    New Friend:
It might be something with the mode. I am trying to turn the date stamp off, and on the factory setting, the basic mode is on. Any advanced settings options disappear when my Polaroid i634 is set back to original settings. Slowly over time, the settings changed, and I don't know how. Somebody just clicked buttons, and all of a sudden, it was a more advanced camera w/ ISO settings, date stamp on/off settings, and what-not.
Posted on Jan 02, 2010
Anonymous
MyCats had the best solution. In my case, ABC Warehouse (Seller) called and asked me if I wanted an extended Warranty. Since it was still in warranty I said no. Guess what happened after the Warranty expired? Yep, the date stuck at 01-01-2003. It's almost if ABC knew something might happen. But then don't they make money on the warranties?
Posted on Oct 09, 2008
Anonymous
Hit is with a Hammer sveral times until it cracks open !!
Anonymous
To set the date and time, select the "M" button and then press the 3:00 o'clock position on the circle button five times. On the page called "Setup", press the 6:00 o'clock position to 'down arrow' to Date/Time. I noticed each time you change your batteries, you have to reset this info. I hope this info helps someone!
Posted on Dec 25, 2007
  • catsnjen Mar 23, 2011
    We know how to set the date and time -- we have to do it every time we turn the darn camera on. The problem is that the camera loses the date and time we've set every time it's turned off, not that we don't know how to set it in the first place. I say "we" because I'm having this problem, too -- starting maybe the 10th time I turned the camera on. Thanks anyway.
Some HDMI Input Picture Settings Grayed out?
It means the settings are not available or needed on HDMI which is High Definition by standard.
HDMI - Wikipedia
https://en.wikipedia.org/wiki/HDMIHDMI (High-Definition Multimedia Interface) is a proprietary audio/video interface for transmitting uncompressed video data and compressed or uncompressed digital audio data from an HDMI-compliant source device, such as a display controller, to a compatible computer monitor, video projector, digital television, or digital ...‎Consumer Electronics Control · ‎Transition-minimized · ‎10K resolution
Google
make model manual
Jan 21, 2018 | Televison & Video
My daughter hit delete all picture on my camara model vpc503. is there any why to get my pictures back.
Sorry no way to restore. Thats why you are prompted more than once to delete all on most things.
Mar 24, 2008 | Cameras
Sanyo put date on pictures
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Mar 25, 2013 | Sanyo Vpc-s1414 14 Mp Digital Camera Vpc S...
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
I have casio ex-z500 camara i want to know how to print date & time in the image
Sep 28, 2009 | Casio Exilim EX-Z500 Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
No input signal after downloading camara photos
check the num lock after power on the machine if it is working it is the problem with monitor otherwise it is the problem with system.
May 17, 2009 | E-Machines eMachines Desktop PC
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Camara not working
try reset ti factory setings. if not, maybe the camera flex needs tobe replace or the camera itself.
Sep 06, 2008 | Nokia N73 Cellular Phone
Polaroid A500 Digital Camera Logo
503 people viewed this question
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
