2003 Chevrolet Tracker Logo
Anonymous Posted on Feb 11, 2011
My brake lights don't work. I've changed the bulbs & checked the fuse. any ideas?
Anonymous
Level 3:
  • Master 4,399 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Answers
4399
Questions
Helped
876588
Points
13003
Check your break switch. It is located under the dash, intact with the break. When you push the break down, it triggers the switch, thus turning on your break lights. They are usually chrome looking and they are round. The break stem that holds the break pedal, when pushed, contacts the break switch. If you need anything else, let us know. Thank you for choosing FixYa. Good day.
Testimonial: "Thank you so much. You're awesome!"
  • Anonymous Feb 11, 2011
    Thanks so much Dakota! I appreciate your comment. Come back anytime and thanks for using FixYa.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
4031
Points
33
You could check the brakelight switch located on the brake pedal linkage. Sometimes they move out of adjustment, sometimes they fail. The ones I've seen are usually plastic and the threads strip off so the jamb nut won't hold the switch in place correctly. It should be round (or at least the part with the mounting nut should be round) with a plug with 2 or 3 wires going into the back and located so that the brake pedal lever moves away from the switch when you push on the pedal. If you deem that it needs to be replaced the switch should be available at most auto parts stores.
Testimonial: "thank you so much! you're a genius!"
  • marvin9679 Apr 05, 2011
    The switch I found only at dealer and have replaced it twice now and have changed the fuses numerous times. The switch is rectangular and has 6 prong plug on it. Replacing it every r months is getting silly. Any ideas?
3 Related Answers
Anonymous
  • Posted on Sep 05, 2008
SOURCE: No rear brake light / turn signals on 2001 Chevy Cavalier
The problem is the turn signal/headlight/hazard switch assembly on the steering column which the brake light wiring runs through. The part is easy to change and cost about $50 at most parts stores
Anonymous
  • 88 Answers
  • Posted on May 23, 2009
SOURCE: rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
Anonymous
  • 4088 Answers
  • Posted on Nov 18, 2009
SOURCE: 2003 trailblazer brake lights do not
Look for a bad common ground connection for the two lights. Modern cars seem to have a problem making secure long-lasting ground points. There may also be a problem with the turn indicator switch as both lights are run through that switch.
3answers
Brake Lights don't work on the back of our 2003 Ford Windstar
Did you actually check the brake light switch for power in and out ?
There are two different fuses, one for each side. And the circuit includes the turn signal switch.
The third brake light bypasses the turn signals.
My turn signals don't work and I've checked the bulbs, fuses & flasher.
About all that is left on the list is the turn signal switch.
Do you have power in and out of the switch ?
How do i fix the brake lights on my mercury sable. all the other lights work fine
Does your car have the `lamp out'indicator system? It's more complicated.
My manual shows fuse #28 , a 15 amp fuse powers the brake bulbs.Is this the one you changed?
A bulb can be out for a long time and you don't notice it,then the other burns out and you think they both went out at the same time,but they might not have,see?
So check the bulbs and make sure you got that brake switch installed correctly. don-ohio (:^)
Head lights work brake lights don't, have changed brake switch and bulbs and checked fuses
When you say you checked the fuse, are you getting power in and out of it and the brake light switch ?
I have a 2002 Hyundai Accent (UK RHD). I've had a headlight go out, side lights and full beam still work. I've changed the bulb and fuse but its still dim. Ran out of ideas...
Hi ,Check the light bulb,see if its seat in the seats properly 'for earth' and the light terminals for dirts ,grease,or corrosion.clean if needs to.I think its a Earth problems
1helpful
Brake light bulb Issue
A bad socket is a common enough problem that it is likely that, rather than a wiring problem. Just splice in a new socket, if you can, or whatever is easier and cheaper (like a tail light assembly from a salvage yard).
Of course if you have a voltmeter or testlight, you can check at the socket electrical connector for power when it should be there-when the brake is pressed.
My 98 ford exsplorer brake lights don't light up, the one on the roof does but the other two don't, I've checked and the bulbs are fine so is the fuse.
Dear,
Please check for either there is a wirring problem.
or might be the bulbs are fuse.
or the fuse for those bulbs are blown off...
kindly check all the aspects and let me know if it does not get solved
thanx
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
2answers
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
