A cold solder joint is a solder attempt that was no heated properly with the soldering tool being used. Most of the time, you can tell a cold solder joint because the solder cools to a dull look; good solder joints look shiny. The solder joint in the picture on the left is dull and you can see there is not good adhesion on the pin terminal for the part being soldered, it was not hot enough for the solder to stick to. The picture on the the right shows a combination of cold joints and lack of enough solder
Hope this helps.
