Sewing Machines Logo
Anonymous Posted on Feb 08, 2011
I recently dusted off my Hobbylock 794 serger. It worked beautifully till I ran out of thread. I have the manual & reviewed it many times. Since I re-threaded the machine will not stitch. I re-threaded many times, checked the needle and although it looked fine I replaced it. I confirmed I'm using the correct kind/size needle. I thoroughly cleaned with lint brush. I checked pressure foot tension. I just can't see what's wrong.
  • 5 more comments
  • Anonymous Feb 09, 2011
    I am already using brand new spools of thread and a brand new needle as mentioned previously. Asdfasdfad's solution stopped mid-sentence "checking the functioning places by checking under" . . . I don't know what I'm supposed to check under. I tried to see what was happening by using the hand wheel with the work support area and looper cover open. It looks like the needle is not catching the thread off the looper.
  • Anonymous Feb 10, 2011
    I requested another expert yet asdfasdfad replied. This reply does not help at all. I don't know what it is I'm supposed to check under the machine and the next sentence is incomplete just like the first reply. Is there a language barrier?
    I did not change the fabric. I don't have a stitching tension issue. The machine will not form stitches at all with or without fabric. The thread feeds through the machine but comes out from behind the pressure foot in 3 single strands - no looping pattern at all is formed with the thread. I am using 3 spools of thread only with the needle in the right side position. This was working just fine till I ran out of thread. I did re-check the machine for proper threading based on your comments and can confirm it is correct.
  • Anonymous Feb 12, 2011
    I already checked thoroughly for any debris in the machine and there is none that I can see.
  • Anonymous Feb 14, 2011
    I don't know what you mean by "check for correct voltage" or "see if all drives are working". How do I do that? The machine goes through the 'motions' as if it is going to stitch but it just doesn't stitch. The threads feed through the machine and come out in 3 single strands - no looping pattern is formed. The machine is not making any unusual sounds and did not make any unusual sounds prior to this problem. It was working - I ran out of thread. I re-threaded and now the machine will not stitch. The moving parts move freely - there is no rubbing or grinding. I cannot see any obstruction.
  • Anonymous May 21, 2013
    Did u ever get hyour Hobbylock #794 to work. It is miserable to thread!!! I use a flashlight. I eally think you are threading it wrong, as tha has happened to me many times in the last 25 years, Please let me know.Maybe I can help. Shelly @ [email protected]
  • Anonymous May 25, 2013
    @Carol Toftum. I have a Pfaff Hobbylock 776 and I have the same exact problem as k_ross2. I spent $140 getting the machine all re-calibrated and cleaned and it worked great til I had to retread. I followed the manual to a "t" or so I thought, but just cannot get it to stitch...just 3 straight threads come out!! What is the special trick? Thanks Kathy
Anonymous
Level 3:
  • Master 591 Answers
  • Posted on Feb 11, 2011
Anonymous
Master
Level 3:
Answers
591
Questions
Helped
172837
Points
2033
Check to see if you have DEBREE that can BLOCK the mechanisme, it happens after cleaning...
good luck!
  • Anonymous Feb 13, 2011
    check for correct voltage to all components, could be a defective DRIVE (motor) see if all drives are working... does it make an unusual sound? try adjusting the tension to -1 first, than adjust to desired tension if it stops than check the drive/mechanism for obstruction...
    good luck!
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Feb 10, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475849
Points
4013
Hello
Your serger tension needs adjusting for each new fabric you use, the thread you use and the type of serging you are doing. It's a pain in the neck when you get everything balanced and then start serging a different weight fabric. It gets easier the more experience you have. Start with all the tensions set at 2 or 3, the differential feed on neutral, the stitch length on 2 or mid point. Then using the fabric you want to serge, use single or double layers, depends on what you intend doing, and stitch for a foot in length.
Chain the fabric off and snip the chaining stitches. Ok look at the underside,, the lower looper creates the loops on the underside, the upper looper creates the loops on the upper side. The left needle catches the lower loops to the left, the right needle stitches between the edge and the where the left needle catches the lower loops.If the under side loops are pulled to the right side the tension is unbalanced between the two loopers, so tighten just the lower looper slightly.
Do anther 12 inches. Still pulling over onto the right side, loosen the upper looper a touch, re stitch. Is the needle thread causing puckers, if it is loosen it slightly, or is it loose underneath, if it is tighten it slightly. Stitches too close together lengthen the stitch length. Is the top layer being stretched, turn the differential feed to the gather symbol a little.
One important thing that gets forgotten is there is no take up arm on a serger, so you must ensure your thread is not delivered straight from the spool to the machine, it must wrap at least once around the thread arm that sits above the spools, and that should be extended upward not telescoped down. Your thread will feed to quickly if you dont bring the thread above it, take it from the front to the back through it, and back over it through the channel or holes provided. That acts as the thread slackness inhibitor.
Always draw your thread down to the loopers and needles with the presser foot raised. When you have balanced your loopers and needle tension, don't forget it is only balanced for the fabric you are trying it on. One setting will not do all fabrics. If your spools bounce use the spool caps that should have come with your machine, they will stop the spinning or jumping but still allow the thread to feed properly.
It used to take me upwards of 30 mins to balance tensions, now it takes me moments. So it does get easier as you get more used to your serger.
THANK YOU FOR VISITING FIXYA
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1163
Points
You might want to get a new thread or a needle
or try checking the functioning places by checking under
    sorry checking under the machine...
    and try to use a different needle tip because if tip isnt getting the thread you cant make the machine going...
I dont know how to thread it, the hobbylock796 serger
Pfaff has the manual for the Hobbylock 796 on their site, http://www.pfaff.com/Support-and-Updates/Support . Use the drop-down menu to find the Hobbylock. The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Hobbylock_794_796-manual-EN.PDF . See pages 7 - 11 for the threading diagrams for a 4-thread double overedge seam. See page 17 for the changes needed for a 3-thread seam. One of the generic threading videos for sergers may help: https://www.youtube.com/watch?v=MrqHC2CNjVI . There's also one for the Pfaff Hobbylock 786: https://www.youtube.com/watch?v=cOZ-djsXdhQ .
I hope these help.
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Price of a hobbylock 4842
Difficult to say. Supposedly original new price was ~$700
Pfaff Serger Overlock Hobbylock 4842 Specifications
However, if it is a used machine, so much is subjective based on physical and operating condition, the accessories included, desirability of the model, where it is located, etc.
PFAFF HOBBYLOCK 4842 SERGER 2 3 4 THREAD OVERLOCK FREE SHIPPING NO RESERVE...
2helpful
2answers
2helpful
2answers
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
I can't find the way to change the left needle.
You can order a manual here - http://www.sewusa.com/Sewing_Machine_Manuals/Pfaff_Manuals/794_796_Hobbylock_Instruction_Manual.htm
In the meantime, contact your local Pfaff dealer. Ask if someone can help you if you bring the serger in.
3helpful
Price of hobbylock 794 in todays market.
Price depends upon how much the machine has been used & what condition it is in. My hobbylock 794 has barely been touched since it was first made and they advised I just throw it out instead when I took it in for a little 'freshening up' at Quality sewing & vacuum in Washington! Everywhere else I've had great feedback that this is a good serger, so check out what similar machines are selling for on Ebay... you could get $100~$400 for your trusty serger {depending on supply & demand}.
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
