20 Most Recent PfaFF Quilt & Craft Pro 7530 Questions & Answers
I have the Pfaff 7530, Quilt and Craft Pro. It is
Hm, this decision is probably too personal for someone else to answer. For what it's worth, there's a 7530 on eBay--bid starting @$650. You'll need to decide if $500 to fix your machine is worthwhile to YOU. How much faith do you have in the repair person? Unfortunately, sometimes, even when machines are repaired, they can still have other parts fail. However, there are repaired machines that will run for another 15 years without any major problems. I'm just assuming (based on the cost), the problem with your machine involves a computer component which is a common issue with computerized machines. Like all computers, there are parts that will fail over time...that's just their nature. For the most part, computers will fail within 5-10 years. However, if they are installing a brand new computer component, it could be like a brand new machine. On the other hand, you know your machine and you know what is wrong with it. Purchasing another used machine leaves you in the dark as far as whether the machine works properly, how it's been treated and serviced, if shipping is involved, will it be packed right and not arrive damaged, etc. Sometimes, just the comfort of knowing that makes your machine worth fixing. If you contemplate replacing your machine, just sit down and make a list of all the options on your machine that you cannot live without. Then set out in search of machines that fill your list of must-haves. The price may help you make your decision.. Finding a new replacement machine could cost a couple thousand dollars. Pfaff Creative 7530 Pre owned sewing machine Thread What would you do Pfaff 7530
11/17/2017 4:24:43 PM • PfaFF Quilt &... • Answered on Nov 17, 2017
Where can I get a manual for this machine?
Search the internet for the machine Brand + Model + the word "Manual." ...
2/29/2016 4:17:36 AM • PfaFF Quilt &... • Answered on Feb 29, 2016
Presser foot lever no longer lowers the foot, just goes up and down
Sounds like the lever has become disconnected from the presser foot bar. ...
11/22/2015 4:50:04 PM • PfaFF Quilt &... • Answered on Nov 22, 2015
Pressor foot will not move down. How do I fix that?
It's probably seizing up. You should take it in to be serviced.
1/8/2015 11:46:33 PM • PfaFF Quilt &... • Answered on Jan 08, 2015
Handwheel very hard to turn on Pfaff 7530
I THINK YOUR BELT IS OUT OF ALIGNMENT. THIS IS A DIFFICULT MACHINE TO WORK ON SO UNLESS YOU WANT TROUBLE YOU BETTER GET A REPAIRMAN.
12/13/2014 1:20:54 AM • PfaFF Quilt &... • Answered on Dec 13, 2014
Seems to be too much gap between pressure foot and tension plate .. material is held loosely
Are the feed dogs completely up? Are the feed dogs worn or clogged with lint and yuck? Is there a presser foot pressure setting dial or knob? Is the correct foot on the machine? Is the presser foot correctly mounted? Is the needle plate correctly mounted?
6/26/2014 3:14:58 PM • PfaFF Quilt &... • Answered on Jun 26, 2014
How do you change straight stitch length?
There is a length switch that you must turn carefully. Just monitor the distance of movement on an old rag and make some marks on the switch or dial as you go.
4/28/2014 2:15:34 AM • PfaFF Quilt &... • Answered on Apr 28, 2014
0answers
Needles keep breaking when embroidering.
Needle breaks1.the needle is damaged2.the needle is not correctly inserted3.wrong size needle for the fabric 4.the wrong foot is attached5.the needle clamp screw is loose6. Top tension is too tight7. Machine could be out of time
10/17/2013 5:06:38 PM • PfaFF Quilt &... • Answered on Oct 17, 2013
2answers
Remove end cover to access changing bulb and cleaning mechanism
Hi paintbox,
There's actually a light-bulb changer available from Pfaff (at least it used to be available). Your Pfaff dealer should be able to get one for you. Makes it a breeze to change lightbulbs.
However... if it is no longer available or your dealer can't get it, you can remove the side cover - raise the handle and look down inside the machine BEHIND the left side of the handle. You should be able to look down inside the machine and see the top of a screw and fit a screwdriver into the space to loosen the cover. Just make sure when you put the cover back on that you tighten the screw down tightly - don't want it falling off while you're sewing!
Hope this helps,
Kim
5/16/2013 7:48:12 AM • PfaFF Quilt &... • Answered on May 16, 2013
Pfaff free motion sewing
Ok.. first understand that free motion is just that.... there will not be a perfect stitch length... You are the regulator of that as you move the hoop. You'll need to practice. There are some good videos on youtube on this.
3/15/2013 5:49:39 AM • PfaFF Quilt &... • Answered on Mar 15, 2013
2answers
Lost electric cord for Pfaff Quilt & Craft Pro 7530. Where can I get one?
sewingpartsonline.com
3/6/2013 3:08:04 AM • PfaFF Quilt &... • Answered on Mar 06, 2013
Sewing Machines Logo
95 questions posted
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
lost electric cord pfaff quilt amp
  • Sewing Machines
