Question about PfaFF Sewing Machines
How do you adjust timing on pfaff 138 sewing machine
How do you adjust timing on pfaff 138 industrial sewing machine
Posted by Michael Carter on
Bruce McCampbell
    New Friend:
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Posted on Sep 22, 2012
  • 2 more comments
  • Bruce McCampbell Sep 22, 2012
  • ruthhook8
    ruthhook8 Oct 07, 2012
    Is there a video I can watch about this problem.
  • ruthhook8
    I want to know what is scarf of the needle?. What is the hook assembly is that the blk plate that covers the metal bottom disc.?.
  • Bruce McCampbell Oct 08, 2012
    The scarf is the indentation of the needle where the eye is located. As the needle rises, the tension of the thread in the fabric causes a small loop to form. As the hook passes the scarf of the needle, it catches the loop and the stitch is locked.
Josiane Chundy
Hi, just got a riccar sewing machine its a used one. when i got home try it , it works but the material does not flow it stuck in place. what can i do.
Posted on Jul 31, 2013
  • sylviaivie Jul 31, 2013
    Hi Josiane:
    Check to see if your Riccar has a switch to drop the feed dogs. If it does return it to sewing mode.
sylviaivie
  • PfaFF Master
  • 1,564 Answers
I found a user manual but not a tech manual. Perhaps this will help some.
http://www.scribd.com/doc/47524441/PFAFF-138-sewing-machine-Manual
Posted on Jul 31, 2012
5 Related Answers
Ed Paje
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
Anonymous
  • 13 Answers
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
Sewtech1
Absolute Sewing
  • 69 Answers
SOURCE: doesa nyone have a pfaff 138-6 manual?
if it is the industrial model, i should have one for you.
Posted on Jun 28, 2009
ken dourof
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
Anonymous
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
Pfaff instructions
here are 2 links, choose which one you want to buy from
Pfaff 138 138 6 Instruction Manual
Pfaff 138 Parts
Jul 11, 2014 | Sewing Machines
I need a manual for the Pfaff 138-6 industrial sewing machine...thank you.
Try the MID WALES SEWING CENTRE Alans Alterations ebay store...they seem to have thousands of sewing machine manuals available.
Mar 22, 2014 | Sewing Machines
We just got a pfaff 138 and put T-90 industrial thread but it keep breaking the thread. i cant figure out why, it seems to be threaded correctly. any thoughts?
You may have a different weight thread in your bobbin and your need may be wrong for your project. Check your manual or call Pfaff.
Sep 19, 2010 | PfaFF Sewing Machines
How do I adjust the timing on a pfaff industrial 545?it will not pick up the bobbin thread at all.
This happened to me. Shucks, I had the wrong needle in; it was too short to reach the bobbin thread and pick it up. Installed correct needle (repair man did) and viola. . .
May 15, 2010 | Sewing Machines
Doesa nyone have a pfaff 138-6 manual?
Jun 28, 2009 | Sewing Machines
Sewing Machines Logo
3,792 people viewed this question
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Asmodius
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
