20 Most Recent PfaFF Hobby 4260 Questions & Answers
3answers
Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
7/5/2020 7:05:50 PM • PfaFF Hobby 4260 • Answered on Jul 05, 2020
2answers
I have a HobbyLock 774 Serger. I just had it
Take it back.
10/11/2017 3:50:13 PM • PfaFF Hobby 4260 • Answered on Oct 11, 2017
Pfaff Select 1540
Search for: sewing machine timing Lots of web sites and videos available.
6/28/2017 2:07:22 AM • PfaFF Hobby 4260 • Answered on Jun 28, 2017
3answers
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
2/14/2015 12:57:01 AM • PfaFF Hobby 4260 • Answered on Feb 14, 2015
2answers
2056 the understitch is loose. Is this a problem
Sounds like a threading problem. Thread the machine all the way to the needle but not the needle eye. Then pull on the thread and lift the presser foot up and down. You should have tension when it is down and no tension when it is up. If this is the case try sewing, should fix the problem. If this is not the case your machine will need to be adjusted buy your pfaff dealer.
Hope this helps
2/16/2014 7:55:48 PM • PfaFF Hobby 4260 • Answered on Feb 16, 2014
Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
12/2/2013 10:24:48 PM • PfaFF Hobby 4260 • Answered on Dec 02, 2013
0answers
2answers
I can't thread the needle
there is a video on utube showing how. Spinktor.
7/30/2013 4:59:30 AM • PfaFF Hobby 4260 • Answered on Jul 30, 2013
2answers
Pfaff Hobbylock 776
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
6/13/2013 6:18:03 AM • PfaFF Hobby 4260 • Answered on Jun 13, 2013
Where can I buy a needle bar for a Pfaff Hobbylock
If you email me your location I can supply you with a new needle bar.
[email protected]
6/13/2013 6:15:46 AM • PfaFF Hobby 4260 • Answered on Jun 13, 2013
Pfaff hobby 1142. only goes one way, does not
it sounds like the buttonhole mechanism is seized up or gummed up with old grease. try following the linkages for buttonhole mechanism or button to see you can locate the stuck linkage.
otherwise it sounds like a tech job.
scott.
5/25/2013 10:07:50 PM • PfaFF Hobby 4260 • Answered on May 25, 2013
I have pfaff 4260 sewing machine.On stiching thread does not interlpcked and fabric can not b stitched properly. I did not find any service centre in Mumbai india. What to do?
I would suggest that you call pfaff because if you do not have a pfaff dealer where you live then you will have to pack it up and ship it to a pfaff dealer that is near to you. Good luck oh and make sure to insure it. Hope that helps
3/8/2013 7:47:56 PM • PfaFF Hobby 4260 • Answered on Mar 08, 2013
2answers
Hello, i am looking for pffaf old model(220) motor
That machine does not have a chain in it. It does have 2 belts a motor belt and a timing belt. Bolth belts very rarely brake. What are the machine symptoms, it may not be a belt at all?
11/1/2012 6:29:11 PM • PfaFF Hobby 4260 • Answered on Nov 01, 2012
Sewing Machines Logo
119 questions posted
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
2056 understitch loose problem
  • Sewing Machines
