Computers & Internet Logo
Posted on Feb 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some times cursor stuck and again start working and some time programmes not responding
Anonymous
Level 2:
  • Expert 253 Answers
  • Posted on Feb 08, 2011
Anonymous
Expert
Level 2:
Answers
253
Questions
Helped
37629
Points
798
FIRST GET YOUR CPU CABINET CLEANED FROM INSIDE .THEN SCAN YOUR SYSTEM FOR VIRUSES USING A GOOD ANTI VIRUS.
Asus g55v My problem was start by yesterday When I start my laptop, it stuck in desktop screen When it respond again, after few minute,it stuck again. After I restart my laptop, It show the same...
Sub out the ram memory one at a time making sure there is one memory stick plugged in at all times. The piece that is left in your hand if this works is the problem.
1helpful
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Decora 6124H Timer
1helpful
Touchpad seems to be sticking
please install ur touchpad driver again
2helpful
2answers
Frozen touchpad
I followed the advice of pressing the FN and F7 keys at the same time. It didn't work when the program was fully loaded, but I rebooted and tried again during the rebooting and it worked. I had the frozen cursor on the Travel Mate (Acer) also.
Mouse doesn't alays work.
check the hard drive for any problems and re-install the drivers for the mouse
1helpful
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
