SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
SOURCE: water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
