From the manual:
This camera does not allow you to insert the shooting date into an image while shooting (date stamping). However you can use the following method to imprint the date while printing.
You can download the manual and guides and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_pro_series/powershot_g10#BrochuresAndManuals
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: I cannot get a date
In order to get the date stamp on the pictures, the resolution/size has to be set to "Postcard". Look at the menu and you will see L, M1, M2, M3, S, and Postcard. Then you can turn on the date stamp option.
SOURCE: how to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The
date will be printed on your images even if it has not been set at the
computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
SOURCE: i have a canon powershot
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
SOURCE: Remove date/time stamp from photos
go to menu at shooting position. scrooll down to date menu and follow the succeding instructions.
