20 Most Recent Canon PowerShot G10 Digital Camera Questions & Answers
If you use the camera cable or a card reader to get the photos on your computer, the metadata is there. When you copy the same picture the metadata is lost and is replaced by the new data at the time it was copied.
Canon PowerShot... | Answered on Oct 31, 2017
One method that may work is to remove the batteries for 24 hours - this might serve to clear down the internal memory.
Canon PowerShot... | Answered on Nov 24, 2016
Some canons have a switch inside the card slot....don't know if you can get at it but you can try things like a dental pick, a toothpick, etc. Be careful.
Canon PowerShot... | Answered on Apr 08, 2016
Canon G10 - Ken Rockwell
www.kenrockwell.com/canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Canon PowerShot G10 Review ' Digital Camera Resource ...
www.dcresource.com/reviews/canon/powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
Canon PowerShot... | Answered on Jan 01, 2016
Restart camera= power off and power on. Probably you have a zoom lens stucked.
Canon PowerShot... | Answered on Dec 04, 2015
Have you tried installing the software and then rebooting the computer. Quite often that's all that's required for the computer to recognize the camera.
Canon PowerShot... | Answered on Jul 20, 2015
Camera is defect for sure, but don't tell anyone in the service centre, because they warn you not to take a camera out in extreme cold. You should not se the camera in environments below zero degrees
I'm afraid you can't fix it yourself, and before bringing it to a Canon Certified repair centre, ask them what it could cost.
Canon PowerShot... | Answered on Mar 01, 2015
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Canon PowerShot... | Answered on Dec 29, 2014
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Canon PowerShot... | Answered on Nov 21, 2014
From the Canon manual: "Error code E32 means the camera was dropped on concrete"
Canon PowerShot... | Answered on Nov 07, 2014
For a lens error on a Canon, we recommend www.CamerasAndParts.com Below is a video on them, they are the best for the Canons
Canon PowerShot... | Answered on Nov 05, 2014
In settings, you might have switched off the image for when the camera starts. Turn it back on. Also, if that doesn't work, try deleting some photos or change the sim card or the battery itself, not charge it.
Canon PowerShot... | Answered on Oct 21, 2014
Go into settings and scroll down, then click reset. You can manually reset it by replacing the sim card or pressing the button inside of the area wher the sim card is.
Go to legalZoom.com and sign in with your email. Fill out the questionnaire for your photo, then at the end you can upload your photo. It should auto save the image in the metadata of photos on the camera and computer you are using if it is done right.
First you press func. set on the video you want to turn up the volume on. When the movie starts press the func. set again and push the up button for the selected volume.
Canon PowerShot... | Answered on May 17, 2014
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Canon PowerShot... | Answered on May 14, 2014
Canon PowerShot G10 Digital Camera Logo
176 questions posted
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
display screen showing pixelated noise
  • Cameras
