Take out memory card from camera, and connect memory card to computer using a card reader, then use this camera recovery software named asoftech data recovery
http://www.asoftech.com/adr/
First of all, you should stop saving any new files to your canon camera (or SD card) or taking new pictures with you camera. Then find some photo recovery software from this site Best Computer Software, which is of high quality and easy-to-use. Digital Photo Recovery for Windows Digital Photo Recovery for Mac OS X Here are the steps: Step 1: Download and install the Digital Photo Recovery Software. Step 2: Connect your camera (or SD card, memory card etc) to your PC or Mac. Step 3: Scan the source drive where your lost pictures located. Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
Don't worry, your lost photos that are very precious can be recovered with ease. I would like to introduce you a very good data Recovery software, called tenorshare data recovery which can be used to recover images from SD card and from other storage devices. This software is an assortment of data recovery components designed for recovering deleted / lost files and folders, photos, RAW images, music & video files from crashed, re-partitioned, accidentally formatted partitions & drives.
You can get it from: http://www.any-data-recovery.com/
Hi,anna_nguyen! You can recover your lost images from your Canon IXUS digital camera with a Canon Photo Recovery program: http://www.canon-photo-recovery.com/ Best wishes!
Remove the memory card from the camera, look along the one edge you will see switch, slide it over. The switch position furthest from the contacts is in the lock position to prevent deletion.
Since that is the case the memory card is defective and to my knowledge you can't access them. The one option you can try is use your computer to upload the pictures, other than that I don't think there is another approach.
I found somebody on this site who is a member, he uses recovery software to get back some or most of the data lost. He also suggested not to put the defective card back in the camera because of possible issues it may cause, you can contact him at www.ruelphoto.com and there will be a charge for sevices.
