20 Most Recent Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera Questions & Answers
Possible that the mic within the camera is bad or there is obstruction to the mic. Please check and clean any dirt , place the camera and shoot without holding to confirm if the sound is better or not.
Canon PowerShot ... | Answered on Nov 27, 2019
Sounds like the CCD or a stuck shutter blade. Try this place: www.CamerasAndParts.com They only service Canons and they are the only place we recommend for the Canons. It's all they work on and they are about half the price of most shops, plus the work is just excellent through them.
Canon PowerShot ... | Answered on Jan 08, 2015
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Canon PowerShot ... | Answered on Apr 29, 2014
Canon europe, In this link the fifth line.
If it does not work, google canon europe and select support. Don't look for the powershot, but for the IXUS.
Digital IXUS 850 IS
Canon PowerShot ... | Answered on Feb 03, 2014
Hey ying1985,
There are a number of programs out there that should recover your pictures from a formatted memory card. A couple of these are CardRecovery v3.00 which cost money, or PC Inspector Smart Recovery which is free.
Sincerely,
Allan
Go Ahead. Use Us.
Canon PowerShot ... | Answered on Dec 05, 2013
I have had success with this... Download this camera photo recovery program called asoftech photo recovery
http://www.asoftech.com/apr/index.html
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Canon PowerShot ... | Answered on Jun 18, 2013
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon PowerShot ... | Answered on Apr 03, 2013
Yes. It's the item marked 2 in the illustration on page 1 of this manual.
Canon PowerShot ... | Answered on Dec 19, 2012
CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Canon PowerShot ... | Answered on Oct 19, 2012
Turn off the camera and took out the battery & memory card. Then sit the camera for 24 hours. After 24 hours insert the battery and memory card and then turn on the camera. No let me know the result.
Canon PowerShot ... | Answered on May 23, 2012
Try the steps in the link below and it should help you fix it.
Click here - > Canon Camera Troubleshooting
Regards,
Suhail
Canon PowerShot ... | Answered on May 17, 2012
I'd stay away from some of the cheaper displays for these cameras. If you want to get the part and have it installed right or even do it yourself, try either www.camerasandparts.com or Canon themselves. They both have the part and both do the service, www.camerasandparts.com deals with the parts and service exclusively on the Canon Powershots, they are about half of what Canon wants for the service on these. Both places do very good work, it's just a little more expensive going directly with Canon.
Canon PowerShot ... | Answered on Dec 12, 2011
Make sure you use a program that recognizes videos.
iPhoto is for still photos. It does not recognize videos. Try iMovie instead.
Canon PowerShot ... | Answered on Oct 31, 2011
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Canon PowerShot ... | Answered on Aug 15, 2011
You can convert photos to black-and-white or add other color effects by adding My Colors effects. Full details are in the "Adding My Colors Effects" section of the Advanced Guide (page 117 in my copy). If you need a manual, you can download it from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_g_series/powershot_s5_is#BrochuresAndManuals
powershot_g_series/
Canon PowerShot ... | Answered on Aug 01, 2011
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
109 questions posted
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
clean lcd display powershot sd850
  • Cameras
