20 Most Recent Canon PowerShot SD3500 IS / IXUS 210 Digital Camera Questions & Answers
Dear Canon Authorities I have
wrong site kindly address your problems to the canon web page , technical support page this fixya site
3/23/2017 11:40:21 PM • Canon PowerShot... • Answered on Mar 23, 2017
0answers
0answers
0answers
Hi, I purchased a replacement LCD
I had a similar problem with a Canon camcorder. I replaced it with a new LCD screen from Rongstar Digital, and it works! Saved a $350 camera for $20! However, installing the new LCD was very difficult, and is not meant to be done by amateurs. You have to be sure the tiny connectors and screws are placed exactly right and in the right order. Don't blame the seller if it does not work!
8/3/2012 9:28:06 PM • Canon PowerShot... • Answered on Aug 03, 2012
Communication error
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
7/13/2012 5:28:59 PM • Canon PowerShot... • Answered on Jul 13, 2012
HOW TO CHANGE LANAGE TO
Press the playback button (right-pointing triangle). Touch and hold MENU (the button at the bottom right of the screen). Touch "English" and then the curving arrow in the top right of the screen.
If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/7/0300003267/01/PSSD3500IS_IXUS210IS_CUG_EN.pdf
The language instructions are on page 21.
9/23/2011 5:19:05 PM • Canon PowerShot... • Answered on Sep 23, 2011
So, when my digital camera
In custom and manual, you're supposed to make the decisions about aperture and shutter speed....are you?
7/1/2011 10:25:53 PM • Canon PowerShot... • Answered on Jul 01, 2011
0answers
MY CANNON IXUS 210 DISPLAYS
This problem is so common, especially with Canon Powershot cameras like your IXUS 210, that there's a whole blog about it here:
http://hubpages.com/hub/Canon_Powershot_Memory_Card_Error_Fix
It seems that the camera gives this error when it has problems reading/writing the card. The fixes they suggest there are to do with cleaning the contacts. It's pretty easy to clean the contacts on the memory card, but much harder to clean the camera. I don't suggest following the instruction to spray cleaner into the slot... that sounds like a recipe for getting it all over the inside of the camera!
I would start by cleaning the memory card's contacts. You can either use a solvent such as Methyl Hydrate and a Kleenex, or you can actually rub the contacts clean with an eraser (or if you're British you can use a solvent such as Methylated Spirit and a tissue, or rub the contacts clean with a rubber). It's probably worth looking inside the camera too, to see if any of the contacts are obviously bent in the card slot. I've seen that in a Nintendo DS which is similar. If a contact is bent, nothing's going to work unless you can get it back in place.
3/23/2011 5:33:07 AM • Canon PowerShot... • Answered on Mar 23, 2011
Hello i have a canon
sounds like an issue with the sd card itself. you may have to reformat it. or CHECK the sd card make sure its not stuckin the the lock position. let me know if that helps.
3/19/2011 10:48:50 PM • Canon PowerShot... • Answered on Mar 19, 2011
How could i take black and white picture with
Press the FUNC/SET button. Use up/down to select "My Colors" (the palette icon). Use left/right to select "B/W" for black-and-white then press FUNC/SET.
3/15/2011 9:21:50 PM • Canon PowerShot... • Answered on Mar 15, 2011
Lens error, does not go back in camera
usuall just get jams up most of the time it get stuck in tho its not commmon for it to get stuck out. i would just try to tap in gently against something. see if it dont free it up.
3/6/2011 9:49:13 PM • Canon PowerShot... • Answered on Mar 06, 2011
How 2 change language settings
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the cursor keys to select a language. Press the FUNC/SET button.
2/18/2011 10:34:54 PM • Canon PowerShot... • Answered on Feb 18, 2011
Change language display ixus 210
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the arrows to select a language. Press the FUNC/SET button.
2/18/2011 10:33:53 PM • Canon PowerShot... • Answered on Feb 18, 2011
Canon PowerShot SD3500 IS / IXUS 210 Digital Camera Logo
44 questions posted
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
change lanage
  • Cameras
